I have a problem with a mass update of multiple lamps at once. I added in total 15 lamps to a group. When I’m switching this group ON or OFF some lamps are not tackled properly. I recognized that the openHab state is set properly because all lamps always receive a correct update. I detected this with some dummy rules like:
rule "f2_floor_lamp_update"
Item f2_floor_lamp received command
logInfo("playground", "f2_floor_lamp recieve command " + receivedCommand)
Next I debugged the hue binding. Here I figured out after setting the bindings log status to DEBUG with:
log:set DEBUG org.eclipse.smarthome.binding.hue
that for these lamps which are not updated correctly the following sequence is not logged:
2018-11-28 22:30:43.349 [DEBUG] [binding.hue.handler.HueBridgeHandler] - Status update for Hue light 1 detected.
2018-11-28 22:30:43.350 [DEBUG] [binding.hue.handler.HueBridgeHandler] - Sending lightStateChanged for light 1
2018-11-28 22:30:43.351 [DEBUG] [binding.hue.handler.HueBridgeHandler] - Sending lightStateChanged for light 1
2018-11-28 22:30:43.352 [DEBUG] [binding.hue.handler.HueBridgeHandler] - Sending lightStateChanged for light 1
Any ideas what’s going wrong here? Is that related to a missing delay which I should configure somewhere in the hue binding?
thanks a lot for these infos! To circumvent this problem I have created a dummy item which i treat as group. Within a new rule I added a short delay after a bunch of 8 items. Now it works fine
Attached the code of this rule if someone needs it:
rule "GMainLivingEnvironmentLamps"
Item GMainLivingEnvironmentLamps_dummyitem received command or
Item GMainLivingEnvironmentLamps_dummyitem_alternative received command
val i = 0
GMainLivingEnvironmentLamps.allMembers.forEach [ item |
item.sendCommand(receivedCommand)
i = i+1
if (i % 8 == 0) {
Thread::sleep(1000)
I have approx 20 hue lights that I give a certain state (on;off;dimmed) in the morning. I see that openhab sends the correct command, the lights are just not on.
Sending the commands a second time usually works.
An other workaround is to define the group (called room or zone) in your HUE bridge and then use the API call to do something with this group. Just 1 command from OH to HUE bridge and the bridge takes care of the rest.
If I remember correctly you have to install the HTTP binding.
The regarding the HUE: First have a look at the HUE-API. You need 3 things.
The first thing is the IP address of you HUE-Bridge. I work with a fixed IP but it should also work with a hostname. The IP of my HUE is 192.168.2.99
Finally you have to find out the ID of the group (the group you’ve defined with the HUE app. https://developers.meethue.com/develop/hue-api/groupds-api/
In the example below the ID of the group is “8” .
Now you have all the info you need.
I first define the URL I have to use, based on the IP, user and group.
Then I define the body of the API.
on = true/false
bri = brightness of the lights (only when on=true)
transitiontime = time to go from current state to new state. In my example = 0 = direct.
Finally I write a line to my log-file, for debugging purposes.
The rule then becomes:
rule "Carport Lights ON at IPCam Motion"
Item IPCam_LineCrossingAlarm received update ON
if (Sun_PhaseName.state!="DAYLIGHT") {
val url = "http://192.168.2.99/api/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/groups/8/action"
val String body = '{"on":true, "bri":254, "transitiontime":0}'
logInfo("HUE API call carport", "Send command '{}' to {}", body, url)
sendHttpPutRequest(url, "application/json", body, 10000)
