Hi, I am using openhab 2.0 offline from openhab.org downloads. And I am using the add on org.openhab.binding.hue-1.8.2.jar. I get the following error when i use log:tail. I have copied this binding in addon folder and in conf/services i have created hue.cgf on my own with refresh, secret and ip adress set according to the “Getting started with openhab 2” wiki.
here is the error
10:52:46.309 [ERROR] [org.openhab.binding.hue ] - [org.openhab.binding.hue(147)] unbind method [removeBindingProvider] not found
10:52:46.310 [ERROR] [org.openhab.binding.hue ] - [org.openhab.binding.hue(147)] bind method [addBindingProvider] not found
10:52:46.433 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=266, bundle=188/file:/home/moisesjimenez/openhab2website/addons/org.openhab.binding.hue-1.8.2.jar]: Unexpected problem updating configuration org.openhab.hue
java.lang.NoClassDefFoundError: Could not initialize class javax.ws.rs.core.MediaType
at com.sun.jersey.core.header.MediaTypes.(MediaTypes.java:64)
at com.sun.jersey.core.spi.factory.MessageBodyFactory.initReaders(MessageBodyFactory.java:182)
at com.sun.jersey.core.spi.factory.MessageBodyFactory.initReaders(MessageBodyFactory.java:176)
at com.sun.jersey.core.spi.factory.MessageBodyFactory.init(MessageBodyFactory.java:162)
at com.sun.jersey.api.client.Client.init(Client.java:342)
at com.sun.jersey.api.client.Client.access$000(Client.java:118)
at com.sun.jersey.api.client.Client$1.f(Client.java:191)
at com.sun.jersey.api.client.Client$1.f(Client.java:187)
at com.sun.jersey.spi.inject.Errors.processWithErrors(Errors.java:193)
at com.sun.jersey.api.client.Client.(Client.java:187)
at com.sun.jersey.api.client.Client.(Client.java:159)
at com.sun.jersey.api.client.Client.create(Client.java:669)
at org.openhab.binding.hue.internal.hardware.HueBridge.(HueBridge.java:52)
at org.openhab.binding.hue.internal.HueBinding.updated(HueBinding.java:295)
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1753)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_91]
10:52:46.437 [ERROR] [org.openhab.binding.hue ] - [org.openhab.binding.hue(147)] unbind method [removeBindingProvider] not found
I know that there is a problem with this hue binding. Is there any new hue binding present for openhab 2.0.
