Therefore i wasn’t able to use the Osram Plug, now i configured it as the type 0100 with the channel brightness and i am a able to switch the plug on/off.
hue.things
I have also added 2 Osram lightify plugs to my Philips Hue and were experiencing similar things as you are.
I do though have it working now as I want. There is a switch channel.
My things file:
I just saw these plugs and I am thinking of using them 2 in same doubleoutlet for toaster and coffemachine with function pressing button on plug will result in 30 minutes of on then auto off.
questions:
I guess making a rule would make it possible to shut off after say 30 minutes every time they are on?
(probably dumb questions but not into OpenHab yet)
can you fit your 2 plugs in same “double-outlet”?
There shouldn’t be any trouble in setting up a rule for shutting off after 30 min. It can easily be done in OH.
To your second question I think you will get in trouble if you try to fit 2 plugs in a double outlet. The plug is quite big and clunky. Your double outlets might be different from mine, so I cannot tell for sure, but they wouldn’t fit in mine side by side.
