I had a working Hue-Openhab 4.0.3 setup but had to change my WLAN installation, so after that the Hue Bridge could no longer be reached by Openhab. It told me to delete the user and let it generate a new one, which I tried, but it just fails. Pressing the button on Bridge does not help either (be it a short, or 10 secs long press):
2024-03-02 12:27:18.936 [INFO ] [ue.internal.handler.HueBridgeHandler] - Creating new user on Hue Bridge XXX .XXX.XXX.XXX - please press the pairing button on the bridge.
2024-03-02 12:27:23.938 [WARN ] [ue.internal.handler.HueBridgeHandler] - Failed creating new user on Hue Bridge
org.openhab.core.i18n.CommunicationException: Total timeout 5000 ms elapsed
at org.openhab.binding.hue.internal.connection.HueBridge.doNetwork(HueBridge.java:1118) ~[?:?]
at org.openhab.binding.hue.internal.connection.HueBridge.post(HueBridge.java:1071) ~[?:?]
at org.openhab.binding.hue.internal.connection.HueBridge.link(HueBridge.java:898) ~[?:?]
at org.openhab.binding.hue.internal.connection.HueBridge.link(HueBridge.java:889) ~[?:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler.createUserOnPhysicalBridge(HueBridgeHandler.java:841) ~[?:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler.createUser(HueBridgeHandler.java:829) ~[?:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler.onNotAuthenticated(HueBridgeHandler.java:812) ~[?:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$PollingRunnable.run(HueBridgeHandler.java:152) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
My Hue Bridge has version 1.62.1962154010.
I can switch on/off lights with the Hue app on my phone and can generate a Matter-Pairing key. I can access the bridge via Browser from my PC. I also tried to follow an old clip API tutorial to create a new user, all I get as response:
"error": {
"type": 101,
"address": "",
"description": "link button not pressed"
Is there anything I can try to get that working again? Preferably without updating Openhab to a newer release, because the Hue Bridge is just a small part and the rest is working as before the WLAN changes (just new ip addresses for the WLAN devices).
