I have setup a Philips Hue bridge with some device and connected it to OpenHAB. I can control the Hue items via OpenHAB.
However, every two minutes OpenHAB finds the Hue bridge again and puts it into PaperUI’s inbox - even though there is already a working Thing and Item configuration for it. The logs are continously polluted by entries like this:
2019-01-02 14:54:49.770 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘hue:bridge:0017886dcc21’ to inbox.
2019-01-02 14:54:49.772 [home.event.InboxAddedEvent] - Discovery Result with UID ‘hue:bridge:0017886dcc21’ has been added.
2019-01-02 14:59:55.818 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘hue:bridge:0017886dcc21’ has been removed.
I had this problem and found that if the name does not match what is in log files it will keep getting discovered. In the log file described above it would be hue:bridge:0017886dcc21
I won’t have access to my files for a week or more. But I may be able to talk you through it.
