Here are the logs after a new discovery:
2016-02-02 10:14:17.305 [WARN ] [javax.jmdns.impl.DNSIncoming ] - DNSIncoming() dump dns[query,192.168.178.20:5353, length=443, id=0x0, flags=0x400:aa, questions=3, authorities=5 questions:
[AllRecords@412518049 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: _hap._tcp.local.]
[AllRecords@605395199 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips-hue.local.]
[AllRecords@1057964040 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips hue - 2066A5._hap._tcp.local.] authorities:
[IPv4Address@384960976 type: TYPE_A index 1, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '119/120' address: '192.168.178.20']
[Pointer@989668897 type: TYPE_PTR index 12, class: CLASS_IN index 1, name: _hap._tcp.local. ttl: '4499/4500' alias: 'Philips hue - 2066A5._hap._tcp.local.']
[Text@849839073 type: TYPE_TXT index 16, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '4499/4500' text: 'c#=1ff=1id=00:...']
[Service@2003667645 type: TYPE_SRV index 33, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '120/120' server: 'Philips-hue.local.:8080']
[IPv6Address@1901568265 type: TYPE_AAAA index 28, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '120/120' address: 'fe80:0:0:0:217:88ff:fe20:66a5']]
question: [AllRecords@412518049 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: _hap._tcp.local.]
question: [AllRecords@605395199 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips-hue.local.]
question: [AllRecords@1057964040 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips hue - 2066A5._hap._tcp.local.]
authoritative: [IPv4Address@384960976 type: TYPE_A index 1, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '119/120' address: '192.168.178.20']
authoritative: [Pointer@989668897 type: TYPE_PTR index 12, class: CLASS_IN index 1, name: _hap._tcp.local. ttl: '4499/4500' alias: 'Philips hue - 2066A5._hap._tcp.local.']
authoritative: [Text@849839073 type: TYPE_TXT index 16, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '4499/4500' text: 'c#=1ff=1id=00:...']
authoritative: [Service@2003667645 type: TYPE_SRV index 33, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '119/120' server: 'Philips-hue.local.:8080']
authoritative: [IPv6Address@1901568265 type: TYPE_AAAA index 28, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '119/120' address: 'fe80:0:0:0:217:88ff:fe20:66a5']
0: 0000040000030000 00050000045f6861 70045f746370056c 6f63616c0000ff80 ........ ....._ha p._tcp.l ocal....
20: 010b5068696c6970 732d687565056c6f 63616c0000ff8001 145068696c697073 ..Philip s-hue.lo cal..... .Philips
40: 20687565202d2032 3036364135045f68 6170045f74637005 6c6f63616c0000ff .hue.-.2 066A5._h ap._tcp. local...
60: 80010b5068696c69 70732d687565056c 6f63616c00000100 01000000780004c0 ...Phili ps-hue.l ocal.... ....x...
80: a8b214045f686170 045f746370056c6f 63616c00000c0001 0000119400261450 ...._hap ._tcp.lo cal..... .....&.P
a0: 68696c6970732068 7565202d20323036 364135045f686170 045f746370056c6f hilips.h ue.-.206 6A5._hap ._tcp.lo
c0: 63616c0014506869 6c69707320687565 202d203230363641 35045f686170045f cal..Phi lips.hue .-.2066A 5._hap._
e0: 746370056c6f6361 6c00001000010000 1194003f0463233d 310466663d311469 tcp.loca l....... ...?.c#= 1.ff=1.i
100: 643d30303a31373a 38383a32303a3636 3a4135096d643d42 5342303032067076 d=00:17: 88:20:66 :A5.md=B SB002.pv
120: 3d312e300473663d 300473233d310463 693d32145068696c 6970732068756520 =1.0.sf= 0.s#=1.c i=2.Phil ips.hue.
140: 2d20323036364135 045f686170045f74 6370056c6f63616c 0000210001000000 -.2066A5 ._hap._t cp.local ..!.....
160: 780019000000001f 900b5068696c6970 732d687565056c6f 63616c000b506869 x....... ..Philip s-hue.lo cal..Phi
180: 6c6970732d687565 056c6f63616c0000 1c00010000007800 10fe800000000000 lips-hue .local.. ......x. ........
1a0: 00021788fffe2066 a500000000000000 0000000000000000 000000 .......f ........ ........ ...
exception
java.io.IOException: Received a message with the wrong length.
at javax.jmdns.impl.DNSIncoming.<init>(DNSIncoming.java:256)[160:org.openhab.jmdns:3.4.2]
at javax.jmdns.impl.SocketListener.run(SocketListener.java:50)[160:org.openhab.jmdns:3.4.2]
[AllRecords@102437858 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: _hap._tcp.local.]
[AllRecords@791410797 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips-hue.local.]
[AllRecords@758560426 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips hue - 2066A5._hap._tcp.local.] authorities:
[IPv4Address@281639765 type: TYPE_A index 1, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '120/120' address: '192.168.178.20']
[Pointer@1318317741 type: TYPE_PTR index 12, class: CLASS_IN index 1, name: _hap._tcp.local. ttl: '4500/4500' alias: 'Philips hue - 2066A5._hap._tcp.local.']
[Text@1040949122 type: TYPE_TXT index 16, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '4500/4500' text: 'c#=1ff=1id=00:...']
[Service@647036175 type: TYPE_SRV index 33, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '120/120' server: 'Philips-hue.local.:8080']
[IPv6Address@2102933851 type: TYPE_AAAA index 28, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '120/120' address: 'fe80:0:0:0:217:88ff:fe20:66a5']]
question: [AllRecords@102437858 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: _hap._tcp.local.]
question: [AllRecords@791410797 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips-hue.local.]
question: [AllRecords@758560426 type: TYPE_ANY index 255, class: CLASS_IN index 1-unique, name: Philips hue - 2066A5._hap._tcp.local.]
authoritative: [IPv4Address@281639765 type: TYPE_A index 1, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '119/120' address: '192.168.178.20']
authoritative: [Pointer@1318317741 type: TYPE_PTR index 12, class: CLASS_IN index 1, name: _hap._tcp.local. ttl: '4499/4500' alias: 'Philips hue - 2066A5._hap._tcp.local.']
authoritative: [Text@1040949122 type: TYPE_TXT index 16, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '4499/4500' text: 'c#=1ff=1id=00:...']
authoritative: [Service@647036175 type: TYPE_SRV index 33, class: CLASS_IN index 1, name: Philips hue - 2066A5._hap._tcp.local. ttl: '119/120' server: 'Philips-hue.local.:8080']
authoritative: [IPv6Address@2102933851 type: TYPE_AAAA index 28, class: CLASS_IN index 1, name: Philips-hue.local. ttl: '119/120' address: 'fe80:0:0:0:217:88ff:fe20:66a5']
exception
2016-02-02 10:14:17.306 [WARN ] [javax.jmdns.impl.SocketListener ] - SocketListener(NexusH.local.).run() exception
java.io.IOException: DNSIncoming corrupted message
at javax.jmdns.impl.DNSIncoming.<init>(DNSIncoming.java:261)[160:org.openhab.jmdns:3.4.2]
Caused by: java.io.IOException: Received a message with the wrong length.
... 1 more
2016-02-02 10:14:17.307 [WARN ] [javax.jmdns.impl.SocketListener ] - SocketListener(NexusH.local.).run() exception
... 1 more
