I am trying to let my hue bulb blink in a specific color if one of my 2 door sensors for the outside gates are open.
I could not figure out why my timer seems to not work
This is my current approach (it is based on Alarmclock whit blinking Light - #2 by rlkoshak from @rlkoshak )
What did I do wrong ?
var Timer lightsBlinkingTimer = null
var String warncolor = "21,100,50"
rule "Tür offen gelassen"
Item XiaomiDoorWindowSensorHaustR_OpenStatus changed
if(XiaomiDoorWindowSensorPforte_OpenStatus.state == OPEN || XiaomiDoorWindowSensorPforteBRo_OpenStatus.state == OPEN){
if(lightsBlinkingTimer != null) {
lightsBlinkingTimer.cancel
lightsBlinkingTimer = createTimer(now.plusSeconds(1), [|
HueLampe_Color.sendCommand(if(HueLampe_Color.state == ON) OFF else warncolor)
lightsBlinkingTimer.reschedule(now.plusSeconds(1))
rule "Stop Blinking"
Item XiaomiDoorWindowSensorPforte_OpenStatus changed from OPEN to CLOSED
log:
2018-03-12 19:45:33.914 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2018-03-12T19:45:33.909+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XFeatureCallImplCustom>.sendCommand(<XIfExpressionImpl>)
<XFeatureCallImplCustom>.reschedule(<XMemberFeatureCallImplCustom>)
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1102) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:763) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy195.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
... 19 more
2018-03-12 19:45:33.923 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2018-03-12T19:45:33.909+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1102) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:763) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy195.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
