I don’t know why but a recent set of Hue bulbs I added to my system is always set to 1% brightness when sending the ON command.
The “LD_Fe_Yttergang_Tak” is a group who LD1 and LD2 is a member of. I also tried using the group item from the hue system (where LD1 and LD2 is combined) but the same problem using that thing ![]()
Anyone else seen this? Using OH 3.4
2023-11-07 06:50:00.214 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LD_Fe_Yttergang_Tak' received command ON
2023-11-07 06:50:00.253 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LD1_Fe_Yttergang_Tak' received command ON
2023-11-07 06:50:00.260 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LD2_Fe_Yttergang_Tak' received command ON
2023-11-07 06:50:00.265 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LD1_Fe_Yttergang_Tak' predicted to become ON
2023-11-07 06:50:00.278 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LD2_Fe_Yttergang_Tak' predicted to become ON
2023-11-07 06:50:00.284 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LD1_Fe_Yttergang_Tak' changed from 0 to 100
2023-11-07 06:50:00.285 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'LD_Fe_Yttergang_Tak' changed from 0.00000000 to 100.00000000 through LD1_Fe_Yttergang_Tak
2023-11-07 06:50:00.286 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LD2_Fe_Yttergang_Tak' changed from 0 to 100
2023-11-07 06:50:09.247 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LD1_Fe_Yttergang_Tak' changed from 100 to 1
2023-11-07 06:50:09.249 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LD2_Fe_Yttergang_Tak' changed from 100 to 1
