I am trying to tag a existing item to 2 bindings - hue emulator & lightwaverf binding, however in either case only the first binding works with the item, I need to control the item below "LRDimmerBulb using Lighwaverf AND hueemulator so do i have to declare this item twice ? one with each binding ? (i assume second item declaration will be discarded by openhab)
I tried to put this together in other bindings {… , [xxx] } and also { …, “xxxx” } but it doesnt work.
anyone using the hue emulator will face the same problem i assume so there must be a way out.
