Hue Emulation with Alexa (TargetTemperature)
All,
I am using Alexa together with the Hue Emulation Binding and it works quite well.
However, I have tagged the thermostat target Temperatur (KM200 Buderus module) like this:
Number 	Heat_HzSollDay	"Zimmertemperatur [%.1f °C]"<heat>			(G_Numbers)			[ "TargetTemperature" ] {km200="service:/heatingCircuits/hc1/temperatureLevels/day"}
However, The item “Zimmertemperatur” is shown as “Lux Light” in the Alexa App after recovering the available Hue things and I get “Temperature is not supported on this device” from Alexa.
I did not find a good documentation about the Hue Emulation, but found this on the HomeKit Documentation (group for thermostat required):
http://docs.openhab.org/addons/io/homekit/readme.html
Obviously this structure is not the same for the Hue Emulation.
Did anyone successfully setup Hue Emulation with Alexa using TargetTemperature?
Does nobody use this function with hue emulation!?
I don’t see the advantage to use the Alexa skill, so I would like to stay with Hue emulation.
i use the hue emulation function with alexa and eq3 thermostate and it works fine…
Hi @horschte,
so you can say: Alexa, please set the living room to 20°C?
Could you please share your items, because the tag “TargetTemperature” is somehow not recognized by Alexa.
yes that works…
here my config
item:
Number WZ_Heizung_Regler  "Heizung [%d %%]"  [ "TargetTemperature" ] {mqtt=">[openhab:set/wz_heizung/desiredTemperature:command:*:default], <[openhab:state/wz_heizung/desiredTemperature:state:default]" }
sitemap:
Setpoint item=WZ_Heizung_Regler label="Heizung Soll [%.1f °C]"   step=0.5 minValue=17 maxValue=30
alexa need the word “celsius”.
for you in german:
correct:
"alexa, zimmertemperatur dreiundzwanzig grad celsius"
false:
“alexa, zimmertemperatur dreiundzwanzig grad”
thanks a lot for your quick response.
I will give it another try!
This works for me, but the temperature set is 1 less than what i say…So if say 29, it will set as 28.
My items file has this entry
Number livingroomac_temp “AC 1[%d °C]” (HVAC) [“TargetTemperature”] { mqtt=">[localhost:/hvac/livingroom/temperature:command:*:default],<[localhost:/hvac/livingroom/temperature:state:default]" }
any idea why?
Are you using a very old openHAB build? If I remember correctly this problem was present almost a year ago …
Nope…I’m using 2.1.0
Looks like there is only a workaround …
Sigh… i guess so…thanks for your help
So the offset of 1 degree is still the case?
