I have three Hue motion/illuminance sensors. Running OpenHABian on milestone builds.
All three Things periodically go into HANDLER_CONFIGURATION_PENDING state. The related things for temp and motion do not experience this issue, and all three go into this state at the same time (I believe). Rebooting the bundle, service or system doesn’t resolve the incident. Only removing and re-adding the thing does:
events.log
2022-03-04 08:41:55.332 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): Missing or invalid configuration.
2022-03-04 09:03:49.661 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): Missing or invalid configuration. to UNINITIALIZED
2022-03-04 09:03:49.689 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-03-04 09:03:51.679 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED (DISABLED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): Missing or invalid configuration.
2022-03-04 09:14:58.261 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): Missing or invalid configuration. to REMOVING
2022-03-04 09:14:58.263 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from REMOVING to REMOVED
2022-03-04 09:14:58.272 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from REMOVED to UNINITIALIZED
2022-03-04 09:14:58.281 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-03-04 09:15:14.659 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'hue:0106:001788462822:123' has been added.
2022-03-04 09:15:21.469 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'hue:0106:001788462822:123' has been removed.
2022-03-04 09:15:21.477 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from UNINITIALIZED to INITIALIZING
2022-03-04 09:15:21.502 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hue:0106:001788462822:123' changed from INITIALIZING to ONLINE
openhab.log
2022-03-04 09:15:14.659 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'hue:0106:001788462822:123' to inbox.
2022-03-04 09:15:21.491 [DEBUG] [ue.internal.handler.HueSensorHandler] - initializeThing thing hue:0106:001788462822:123 bridge status ONLINE
I believe this started with 3.2.0 (not 100% sure) but has persisted with 3.3.0M1 and 3.3.0M2.
I’ve turned on debugging for the hue bundle but can’t seem to find anything - maybe I should be logging against a different bundle?
