Hey something happened, and i am unsure when it happened, however.
I have this:
And i have the following ITEM:
Number Hue_Motion_Sensor_1_illu “Pir Illu” (All) {channel=“hue:0106:ecb5fa004a16:35:illuminance”}
It stopped working, and is always showing 10000.0
(I use the illumination level for “monitoring when its dark enough”)
all other values, like temperature and motion detection is working as expected.
I do not see any other writings of this.
I dismounted the sensor and inside the hue app i can adjust the light level fine.
I also changed batteries, which had no obvious effect.
So something must have happened.
I am probably not on the newest version (openHAB 3.4.4), but since it have worked previously i would assume that eighter openbhab or hue changed something.
Personally I am not working on any API v1 stuff. My personal focus is on API v2 (as Philips/Signify too). And from this, the focus #1 is towards OH v4.0x, although I plan to do a final back port to OH v3.4.x (API v2) in the next few days. So maybe the migration of your system from API v1 to v2 will fix it for you. However this is unfortunately not without effort…
