Does anybody know, if the Philips Hue Outdoor Sensor https://www2.meethue.com/en-gb/p/hue-outdoor-sensor/8718699625474
works with the Hue Binding.
Is the luminance sensor accessible?
Thanks in advance!
According to the binding’s doc (Philips Hue - Bindings | openHAB) this should be possible since hue sensors are basically supported. And reading a bit about this sensor it seems that is the same as the indoor sensor but with a better detection angle, better range and with a suitable casing for outdoor usage
Thanks, so it’s worth a try.
Have you tried it, did it work?
I tested it and as far as I remember, it worked. But I have no longtime experiences, because I don’t use the ZigBee binding anymore.
