Hi all,
during testing the Hue Play HDMI Sync Box Binding Iโve noticed, that my current implementation changes the UID of the thing if the discovered device is added with a custom id. As a result, the already added device is added again - as the UID of the discovered thing does not match the device added with a custom id.
Is this behaviour expected, or do I need to modify the handling of the ThingUID creation to avoid this effect. I was a bit surprised, that the ID and UID influence each other.
Advice is appreciated - ideal would be a โbest practiceโ implementation example I could use as inspiration.
As the openHAB 4.3 preview builds are available now, I would like to merge soon to include the binding in the preview builds to have better test coverage. Therefore I would like to avoid a complex UID/ID handling if it is not necessary - or an easy solution is already available.
with kind regards,
Patrik
