val randHue = (Math::random * 360).intValue + 1// Math::random macht eine zufällige Zahl zwischen 0.0 und 1.0 und wird maximal 360 (Colorwheel hat 360Grad)
val randSat = 100 //(Math::random * 100).intValue
now I only want to send a new Color if it different.
I try to monitor if the light makes any change.
If i want to make a change i have to send a command first. So my system will pass it.
If i want to set a brightness or color i have to know if i have to send a command first.
How can I read out the Hue and Sat and brightness and compare them with my new Values.
If you send a command for 70 and the value is already 70 then use return; at the end of the if statement. This will simply do nothing, you can then send a different value to have it change.
Use postUpdate on the item to give the current value.
