S1585. @David_Graeff, I’m testing out the new version. I had used the previous versions and have 84 Items (and groups) tagged with Switchable, Lighting, or ColorLighting. /api/status shows 77 lights and 501 sensors. It looks like I have to tag 494 Items with ‘internal’ to prevent them from being discovered!
The documentation is not very clear on this, but this is my understanding of when Items will be discovered…
If they have a Lighting category
If they have a Switchable, Lighting, or ColorLighting tag
NOT if they are tagged with internal
Why were the following Items discovered, as it doesn’t seem to follow the strategy outlined in the doc (these are just a few random examples of the 494)…
Number Outside_Patio_US_Bedroom_Dimmer_Scene "US Bedroom: Patio: Scene [%d]" <text> (gOutside,gScene) {channel="zwave:device:073540a2:node28:scene_number"}
Number Lock_Workshop_Battery "Workshop: Battery [%d %%]" <energy> (gWorkshop,gDoorLock,gBattery) {channel="zwave:device:073540a2:node132:battery-level"}
Number Energy_Usage_Monthly "Last 30-day Energy Usage [%.0f kWh]" <energy> (gHEM1)
Dimmer US_MasterBedroom_Kodi_Volume "Kodi (Upstairs Bedroom) Volume [%d]" <soundvolume> (gKodi_Bedroom_Upstairs) { channel="kodi:kodi:bedroomupstairs:volume" }
Group gGarageDetached "Garage Detached" <garage> (gOutside)
This is way too ‘greedy’ (as you put it in the doc) for me. I want none of my Items to be discovered unless specifically tagged, like it was before. I tried clearing the ignoreItemsWithTags in the hope that an empty list would pick up Items without tags, but I wasn’t so lucky .
Also, why doesn’t the Hue-Type depend on the Item type?
I updated my whole setup from Ri3+ openhab 2.4 to RPi4 openhab 2.5.1.
The main reason updating to openhab 2.5.1 was that alexa can’t control the hue emulated device anymore.
After all work was done, I tagged only 5 items of 200 with the “Ligthing” tag.
I read already that the hue emulaiton service exposed everything in Version 2.5.
But should it not ignore the items which are tagged as “internal”?
Tagged items with internal where also exposed.
Why the hue emulation cant works like in Verison 2.4 where only the tagged item where exposed??
There is open issue, but the last post is from july
Can anybody help me to expose alexa only the 5 zwave items.
OK, I moved forward to tagged items will be discovered by alexa.
I remove hueemulation from addons.cfg
Delete all config files related to hueemulation
Restart Openhab
Install hueemulation from Paperui
Start pairing
And forward port 80 to 8080
Now I have the problem that ID are mixed between the hue emulation and the hue hub.
I want to turn on a hue bulb (like “alexa, turn on dinning room”) instead a hue emulated item turns on (like living room)
HueEmulation creates an internal mapping of your Thing Channels to numbers.
If you reinstall hue emulation (= purging that mapping) a new one is created.
The Hue protocol identifies lights purely by those numbers. The only way to solve this is to perform a rediscovery on all your Hue protocol using devices like Alexa, Google Home, Logitech harmony etc. This is nothing that can be “fixed” on OHs side. Alexa is particularly stubborn and you probably need to remove devices one by one.
I got it. Now my setup is running with all emulated and real hue items.
I already use the hue binding to control the real hue items with OH.
I tagged these items also as “lighting”. Use the Hue emulation to make them discoverable for alexa.
Discover all tagged items with alexa.
Delete the item in alexa which are from the hue bridge.
