[huesync] - Patched version for 4.3.2 to address Issue #18062
Hi all,
the initial version of the huesync binding introduced with openHAB 4.3.x has an annoying issue. In case of communication problems the configuration/token is lost.
I’m working on a fix for
[huesync] Configuration (API Token) lost if device goes offline · Issue #18062 · openhab/openhab-addons · GitHub.
A back-port to 4.3.x is available. If you’re affected and/or would like to help to test the changed/improved exception handling you can uninstall the official version and use the patched one:
:fast_down_button: org.openhab.binding.huesync-4.3.2.jar
Feedback is highly appreciated.
The code changes are visible in this draft PR:
https://github.com/openhab/openhab-addons/pull/18100
Feel free to comment on the code as well if you see something that should be improved/discussed.
With kind regards,
Patrik
