I want to share my solution for regulating humidity indoors.
Concept
I do not like the dry air indoors in winter. So I got myself a humidifier:
It’s a finde device with a couple of glitches though:
- It does not turn on/off automatically
- It does not measure Humidity
- The water tank only lasts for about 11h, then you need to refill water.
We can see, this thing desperately needs automation
Automation of the Humidifier
I installed an indoor Temperature sensors (Aqara Temp/Hum Sensor). Every 30min it broadcasts temp/hum.
Number Sensor2_Humidity "Humidity Livingroom [%d %%]" (fg_gAqara,gGF_gHumidity) {mqtt="<[MQTT:mqtt/zigbee2mqtt/Aqara_TempSensor2:state:JSONPATH($.humidity)]"}
With the help of a smart plug of your choosing it is quite sraight forward to turn on the Humidifier, when Humidity is below 37% and turn it off again when it is above 42% (whatever values you deem necessary).
Note: I took out all logInfos but I highly recommend using them when making rules, they immensly helped me to see where the problem is. Especially with timers.
rule "Humidifier on/off"
Item Sensor2_Humidity changed
val Number humidityHigh = 42
val Number humidityLow = 37
val Number humidityCurrent = Sensor2_Humidity.state as DecimalType
if (humidityCurrent <= humidityLow) { LivingRoom_Humidifier_Power.sendCommand(ON)
else if (humidityCurrent >= humidityHigh) { LivingRoom_Humidifier_Power.sendCommand(OFF)
I did not implement threshholds, because the update interval is 30min, so min runtime of the Humidifier will be 30min which I can live with.
So 1 and 2 are already solved. Let’s get to #3
Make sure that the Humidifier does not run when empty
I had to remind myself that openhab is event driven.
I added a couple of extra items:
Number LivingRoom_Humidifier_TimeRemain "Remaining Time to refill [%d]"
Switch LivingRoom_Humidifier_Empty "Empty"
The basic idea is that the Switch _Empty is turned to on, when TimeRemain=0
Additionaly above rule needs a slight modification, as we only want it to trigger when the tank is not empty.
So just add:
if (LivingRoom_Humidifier_Empty.state==OFF){
//the rest of the rule goes here
Creating a runime Counter
Now let’s configure a timer to determine then the Empty Tank event actually occurs:
The idea:
whenever the Humidifier is turned on, take the remaining time that is left until the tank is empty.
If the remaining runtime reaches 0 - turn off the humidifier and notify that it’s empty.
var Timer remainingTimeCounter=null
rule "Remaining"
Item LivingRoom_Humidifier_Power changed to ON
var remainingTime = LivingRoom_Humidifier_TimeRemain.state as Number
remainingTimeCounter = createTimer(now.plusMinutes(1), [|
if(remainingTime > 0){
remainingTime = remainingTime - 1
LivingRoom_Humidifier_TimeRemain.postUpdate(remainingTime)
if(remainingTime <= 0 ) {
LivingRoom_Humidifier_Empty.sendCommand(ON)
remainingTimeCounter.reschedule(now.plusMinutes(1))
So every Minute the Item LivingRoom_Humidifier_TimeRemain
is updated, then the timer is rescheduled. If the Item LivingRoom_Humidifier_TimeRemain
equals 0 the Humidifier will be turned off.
Note: By separation the On/OFF rule and the Remaining Time Counter we make sure, that the remaining time also updates when the Humidifier is turned on manually.
Now we need a rule that cancels the timer, when the humidifier is turned off (be it by hand or automatically)
rule "cancel Timer when Humidifier is turned off"
System started or
Item LivingRoom_Humidifier_Power changed to OFF
remainingTimeCounter?.cancel
remainingTimeCounter = null
Finally we need a rule that resets the remaining time to 11h, when the tank is refilled.
rule "Humidifier refill is done"
Item LivingRoom_Humidifier_Empty changed to OFF
LivingRoom_Humidifier_Empty.sendCommand(OFF)
LivingRoom_Humidifier_TimeRemain.postUpdate(660)
There you go. For convenience one might want to add a proxy item for Refill. That way you can refill the tank (thus resetting the remainTime to 11h) even if the tank was not empty.
