Humidity-Calculator [5.2.0.0;5.9.9.9]
material-symbols--dew-point
  1. Calculator → Calculate absolute humidity, dew point, vapor pressure, or wet-bulb temperature from temperature and relative humidity.
  2. Comparison → Compares absolute humidity or dew point between two locations using their temperature and humidity sensors. Writes the difference (positive if Location 1 exceeds Location 2) to a target item, either as a percentage or in Kelvin/°C.
    Language: JS Scripting Scripting with openhab-js 5.18.2
Dependencies:
openhab-js 5.18.2 or later
Changelog
Version 0.1.1
  • when comparing ( dew point control) no unit is supplied.
Version 0.1
  • initial release
Bug reports and improvement suggestions are highly encouraged.
Resources
version: 1
ruleTemplates:
  oh-Humidity-Calculator:
    label: oh-Humidity-Calculator
    description: Calculate absolute humidity, dew point, vapor pressure, or wet-bulb temperature from temperature and relative humidity.
    tags:
      - Version_0.1
    configDescriptions:
      Temp:
        label: temperature
        description: Number Item with unit °C/°F
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Hum:
        label: relative humidity
        description: Number Item with percent
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Pressure:
        label: pressure
        description: "<b>Optional</b> Improved accuracy for wet-bulb"
        context: item
        required: false
        default: 'undefined'
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Ziel:
        label: target Item
        description: Item for return value. OH handles the conversion to the desired unit.
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Parameter:
        label: Parameter
        required: false
        defaultValue: Humidity
        type: TEXT
        options:
          - label: 'absolute humidity g/m³'
            value: 'Humidity'
          - label: 'dew point °C/°F'
            value: 'dewPoint'
          - label: 'vapor pressure hPa'
            value: 'vaporPressure'
          - label: 'wet-bulb °C/°F'
            value: 'wetBulb'
    triggers:
      - id: Temp_trigger
          itemName: "{{Temp}}"
        type: ItemChanged
      - id: Hum_trigger
          itemName: "{{Hum}}"
        type: ItemChanged
    actions:
      - id: "oh-Humidity-calculator_action"
        label: "oh-Humidity-calculator"
        description: Created with Rule Templates
        type: Script
          type: javascript
          script: |
            'use wrapper=true'
            function fTaupunkt(r, t, press) {
                if (isNaN(r) || isNaN(t)) {
                  return { dewPoint: 'NaN', Humidity: 'NaN', vaporPressure: 'NaN', wetBulb: 'NaN' };
                const mw = 18.016;
                const gk = 8314.3;
                const t0 = 273.15;
                const tk = t + t0;
                const a = (t >= 0) ? 7.5 : 7.6;
                const b = (t >= 0) ? 237.3 : 240.7;
                const sdd = 6.1078 * Math.pow(10, (a * t) / (b + t));
                const dd = sdd * (r / 100);
                const af = (Math.pow(10, 5) * mw / gk) * (dd / tk);
                const v = Math.log10(dd / 6.1078);
                const tt = (b * v) / (a - v);
                // Stull-Basisformel (für Standarddruck kalibriert)
                let tw = t * Math.atan(0.151977 * Math.pow(r + 8.313659, 0.5)) +
                    Math.atan(t + r) -
                    Math.atan(r - 1.676331) +
                    0.00391838 * Math.pow(r, 1.5) * Math.atan(0.023101 * r) -
                    4.686035;
                // Einfache empirische Druckkorrektur (Näherung)
                // Bei niedrigerem Druck verdunstet Wasser leichter -> tw sinkt leicht
                const pruckKorrektur = (1013.25 - press) * 0.0008;
                tw = tw - pruckKorrektur;
                return {
                  InputTemp: `${t.toFixed(2)} °C`,
                  InputHum: `${r.toFixed(2)} %`,
                  dewPoint: `${tt.toFixed(2)} °C`,
                  Humidity: `${af.toFixed(2)} g/m³`,
                  vaporPressure: `${dd.toFixed(2)} hPa`,
                  wetBulb: `${tw.toFixed(2)} °C`
            const getPressureValue = (itemName) => {
              if (!itemName || itemName === 'undefined' || itemName === '') {
                return 1013.25;
              try {
                const qState = items.getItem(itemName)?.quantityState;
                const value = qState ? qState.toUnit('hPa')?.float : NaN;
                return !isNaN(value) ? value : 1013.25;
              } catch {
                return 1013.25;
            const getTempValueCelsius = (itemName) => {
              const qState = items.getItem(itemName).quantityState;
              return qState.toUnit('°C').float;
            const outcome = fTaupunkt(
                items.getItem('{{Hum}}').numericState,
                getTempValueCelsius('{{Temp}}'),
                getPressureValue('{{Pressure}}')
            // console.warn('E= ', outcome);
            items['{{Ziel}}'].postUpdate(outcome.{{Parameter}});
  oh-Humidity-Comparison:
    label: oh-Humidity-Comparison
    description: Calculates the humidity difference between two Location
    tags:
      - Version_0.1.1
    configDescriptions:
      Temp1:
        label: Location 1 - temperature
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Hum1:
        label: Location 1 - relative humidity
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Temp2:
        label: Location 2 - temperature
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Hum2:
        label: Location 2 - relative humidity
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Ziel:
        label: target Item
        description: Item for return value. The result is positive if the humidity in Location 1 > Location 2.
        context: item
        required: true
        type: TEXT
        filterCriteria:
          - name: type
            value: Number
      Parameter:
        label: Parameter
        description: Set the unit for the dew point item to K or °C. Converting not meaningful.
        required: false
        type: TEXT
        options:
          - label: 'absolute humidity, Return difference in %'
            value: 'Humidity'
          - label: 'dew point, Return difference in K'
            value: 'dewPoint'
    triggers:
      - id: Temp_trigger1
          itemName: "{{Temp1}}"
        type: ItemChanged
      - id: Hum_trigger1
          itemName: "{{Hum1}}"
        type: ItemChanged
      - id: Temp_trigger2
          itemName: "{{Temp2}}"
        type: ItemChanged
      - id: Hum_trigger2
          itemName: "{{Hum2}}"
        type: ItemChanged
    actions:
      - id: "oh-Humidity-Comparison_action"
        label: "oh-Humidity-Comparison"
        type: Script
          type: javascript
          script: |
            'use wrapper=true'
            let outcome_Ziel = '';
            function fTaupunkt(r, t) {
                  return { dewPoint: 'NaN', Humidity: 'NaN'};
                const mw = 18.016;
                const gk = 8314.3;
                const t0 = 273.15;
                const tk = t + t0;
                return {
                  dewPoint: tt,
                  Humidity: af
            let getTempValueCelsius = (itemName) => {
              let qState = items.getItem(itemName).quantityState;
            const outcome_1 = fTaupunkt(
                items.getItem('{{Hum1}}').numericState,
                getTempValueCelsius('{{Temp1}}')
            const outcome_2 = fTaupunkt(
                items.getItem('{{Hum2}}').numericState,
                getTempValueCelsius('{{Temp2}}')
            if ('{{Parameter}}' == 'Humidity'){
                outcome_Ziel = ((outcome_1.Humidity - outcome_2.Humidity) / outcome_2.Humidity * 100).toFixed(3) + ' %';
            }else{
                outcome_Ziel = (outcome_1.dewPoint - outcome_2.dewPoint).toFixed(3);
            // console.warn('E=', outcome_Ziel, '; L1=', outcome_1, '; L2=', outcome_2 );
            items['{{Ziel}}'].postUpdate(outcome_Ziel);
My example versioning were wrong. The open ended versioning like this won’t work. Change your title to use [5.2.0.0;5.9.9.9] to have the entry show up properly in the Add-on store.
But thanl you for posting a tempalte! I’ve been trying to get more people to do so for years.
Nice work! Being able to compare dew points and absolute humidity between different rooms sounds really useful for home automation. This could be especially helpful for monitoring indoor humidity and spotting potential condensation issues.
