Hi all. I have a fresh install of 4.1 and I’ve decided to create everything from scratch. I have this weird issue with inconsistent displaying of Humidity measurement.
Humidty value comes from mqtt as integer. When I configure it as a Dimensionless (one) point (with added % to State Description Pattern, I get the results as presented below: value in the bottom part is presented correctly, while the derived value for the location shows 0. Interestingly, at the same time logs show 15:23:09.883 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iLWYWSSalonHumi' changed from 0.45 to 0.46
, with the value off by factor of 100.
When I recreate the point but I select empty dimension, the location tab header gets proper humidity value, but the value for the sensor is then shown without %.
Is that a bug/inconsistency, or expected behavior?
