Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 5.10.17-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
openHABian 3.1.0
I am running into the same problem again and again.
I copied the design of my overview page from this shared post:
So I got for every room a widget which contains the temperature and also the humidity.
The overview page is displaying the humidity constant and correctly.
But, when I click on the Widget for example “Küche” there only will be sometimes the humidity displayed.
The ITEM for the humidity is the same, as I use for the overview page.
It is very confusing, cause sometimes (random) the humidity is shown in the widget.
I can’t figure out at which point this happens.
But at the moment it is working for the room “Wohnzimmer” which also has the same widgets.
So the widget should work too ?
Someone got a hint, why the percentage of the Humidity is randomly shown ?!
Item works correct and widget works sometimes ?
Code for widget “Temperatur”
uid: Cell_Temp_Card_1
tags: []
props:
parameters:
- description: Small title on top of the card
label: Title
required: false
type: TEXT
- description: Icon on top of the card (only f7 icons (without f7:))
label: Icon
required: false
type: TEXT
- description: in rgba() or HEX or empty
label: Background Color
required: false
type: TEXT
- context: item
label: Current Temperature
required: false
type: TEXT
- context: item
label: Set Temperature
required: false
type: TEXT
- context: item
label: Current Humidity
required: false
type: TEXT
- context: item
description: on/off item
label: Heating control item
required: false
type: TEXT
parameterGroups: []
timestamp: Jul 9, 2021, 10:18:59 AM
component: f7-card
style:
noShadow: false
padding: 0px
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
background-color: "=props.bgcolor ? props.bgcolor : ''"
height: 120px
margin-left: 5px
margin-right: 5px
slots:
content:
- component: f7-block
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
- component: f7-icon
f7: =props.icon
style:
margin-right: 10px
visible: "=props.icon ? true : false"
- component: Label
text: "=props.title ? props.title : ''"
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -20px
left: 16px
flex-direction: row
slots:
default:
- component: Label
text: "=items[props.temp_item].displayState ? items[props.temp_item].displayState : items[props.temp_item].state"
style:
font-size: 22px
font-weight: 400
margin-left: 0px
margin-top: 0px
style:
position: absolute
bottom: -40px
left: 12px
flex-direction: row
display: flex
slots:
default:
f7: drop
visible: "=props.humidity_item ? true : false"
- component: Label
text: =items[props.humidity_item].displayState
style:
font-size: 12px
margin-left: 5px
margin-top: 0px
style:
position: absolute
bottom: -63px
left: 12px
flex-direction: row
display: flex
slots:
default:
visible: "=props.heating_item ? true : false"
f7: flame
- component: Label
text: =items[props.heating_item].state
style:
font-size: 12px
margin-left: 5px
margin-top: 0px
- component: oh-button
visible: "=props.set_temp_item ? true : false"
iconColor: red
iconF7: arrow_up_circle
iconSize: 35
action: command
actionItem: =props.set_temp_item
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) + 0.5
style:
position: absolute
top: 12px
right: 10px
height: 35px
background: transparent
iconColor: red
iconF7: arrow_down_circle
iconSize: 35
action: command
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) - 0.5
style:
position: absolute
top: 74px
right: 10px
height: 35px
- component: Label
text: =items[props.set_temp_item].state
style:
font-size: 12px
position: absolute
right: 15px
top: 50px
style:
position: absolute
top: 15px
left: 15px
width: "=props.set_temp_item ? 'calc(100% - 55px)' : '100%' "
height: 120px
slots:
default:
- component: oh-trend
trendItem: =props.temp_item
trendGradient:
- "#aa2b1d"
- "#cc561e"
- "#ef8d32"
- "#beca5c"
style:
--f7-theme-color-bg-color: transparent
background: var(--f7-theme-color-bg-color)
filter: opacity(30%)
position: absolute
width: 100%
height: 100%
top: 0px
left: 0px
z-index: 1
- component: oh-link
actionAnalyzerChartType: day
action: analyzer
actionAnalyzerItems: "=props.set_temp_item ? [props.temp_item, props.humidity_item, props.set_temp_item] : (props.humidity_item ? [props.temp_item, props.humidity_item] : [props.temp_item])"
actionAnalyzerCoordSystem: time
style:
position: absolute
left: 0px
top: 0px
height: 120px
