I am trying to connect a Hunter Pro-HC irrigation controller to Openhab.
I installed Hydrawise Binding and connected the controller, but in the documentation I did not find an example for the .sitemap file
I only found this example for the .items file
Group Sprinkler "Sprinkler"
Group SprinklerController "Controller" (Sprinkler)
Group SprinklerZones "Zones" (Sprinkler)
Group SprinklerSensors "Sensors" (Sprinkler)
Group SprinkerForecast "Forecast" (Sprinkler)
String SprinkerControllerStatus "Status [%s]" (SprinklerController) {channel="hydrawise:controller:myaccount:123456:controller#status"}
Number SprinkerControllerLastContact "Last Contact [%d]" (SprinklerController) {channel="hydrawise:controller:myaccount:123456:controller#lastcontact"}
Switch SprinklerSensor1 "Sprinler Sensor" (SprinklerSensors) {channel="hydrawise:controller:myaccount:123456:sensor1#active"}
Group SprinkerForecastDay1 "Todays Forecast" (SprinkerForecast)
Number:Temperature SprinkerForecastDay1HiTemp "High Temp [%d]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#temperaturehigh"}
Number:Temperature SprinkerForecastDay1LowTemp "Low Temp [%d]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#temperaturelow"}
String SprinkerForecastDay1Conditions "Conditions [%s]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#conditions"}
String SprinkerForecastDay1Day "Day [%s]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#day"}
Number SprinkerForecastDay1Humidity "Humidity [%d%%]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#humidity"}
Number:Speed SprinkerForecastDay1Wind "Wind [%s]" (SprinkerForecastDay1) {channel="hydrawise:controller:myaccount:123456:forecast1#wind"}
Group SprinklerZone1 "1 Front Office Yard" (SprinklerZones)
String SprinklerZone1Name "1 Front Office Yard name" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#name"}
Switch SprinklerZone1Run "1 Front Office Yard Run" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#run"}
Switch SprinklerZone1RunLocal "1 Front Office Yard Run (local)" (SprinklerZone1) {channel="hydrawise:local:home:zone1#run"}
Number SprinklerZone1RunCustom "1 Front Office Yard Run Custom" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#runcustom"}
DateTime SprinklerZone1StartTime "1 Front Office Yard Start Time [%s]" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#nextruntime"}
Number SprinklerZone1TimeLeft "1 Front Office Yard Time Left" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#timeleft"}
String SprinklerZone1Icon "1 Front Office Yard Icon" (SprinklerZone1) {channel="hydrawise:controller:myaccount:123456:zone1#icon"}
Group SprinklerZone2 "2 Back Circle Lawn" (SprinklerZones)
String SprinklerZone2Name "2 Back Circle Lawn name" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#name"}
Switch SprinklerZone2Run "2 Back Circle Lawn Run" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#run"}
Switch SprinklerZone2RunLocal "2 Back Circle Lawn Run (local)" (SprinklerZone2) {channel="hydrawise:local:home:zone2#run"}
Number SprinklerZone2RunCustom "2 Back Circle Lawn Run Custom" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#runcustom"}
DateTime SprinklerZone2StartTime "2 Back Circle Lawn Start Time" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#nextruntime"}
Number SprinklerZone2TimeLeft "2 Back Circle Lawn Time Left" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#timeleft"}
String SprinklerZone2Icon "2 Back Circle Lawn Icon" (SprinklerZone2) {channel="hydrawise:controller:myaccount:123456:zone2#icon"}
Group SprinklerZone3 "3 Left of Drive Lawn" (SprinklerZones)
String SprinklerZone3Name "3 Left of Drive Lawn name" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#name"}
Switch SprinklerZone3Run "3 Left of Drive Lawn Run" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#run"}
Switch SprinklerZone3RunLocal "3 Left of Drive Lawn Run (local)" (SprinklerZone3) {channel="hydrawise:local:home:zone3#run"}
Number SprinklerZone3RunCustom "3 Left of Drive Lawn Run Custom" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#runcustom"}
DateTime SprinklerZone3StartTime "3 Left of Drive Lawn Start Time" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#nextruntime"}
Number SprinklerZone3TimeLeft "3 Left of Drive Lawn Time Left" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#timeleft"}
String SprinklerZone3Icon "3 Left of Drive Lawn Icon" (SprinklerZone3) {channel="hydrawise:controller:myaccount:123456:zone3#icon"}
Can someone help me with an example for the .sitemap file?
Thank you
