Hello Everyone,
I’ve been trying to figure out how to add my Daikin AC-s into Google Home, to be able to voice control them via Google Assistant in OH 3.1
I’ve read through the OH 3.1 GA page, and have checked some of the users .items files but I’m not able to properly configure my items, so the AC would show up properly in Google Home.
My basic problem is that my AC does not have and OFF mode under “modes”, it has a switch from which it can be turned ON and OFF.
If I edit the ga=Thermostat group to have my AC’s possible modes (modes=“AUTO, DEHUMIDIFIER, COLD, HEAT, FAN”) then I’ll have no chance to turn it on or off. If I add an OFF/ON value to the modes I got error in the logs that the ON / OFF state is not a valid MODE value.
Here is my allAC.items file:
Group gGAHaloAC { ga="Thermostat" [ thermostatTemperatureRange="16,32", useFahrenheit=false, roomHint="Bedroom" ] }
//HÁLÓ KLÍMA//
Switch DaikinHaloPower "Bekapcsolás" <climate> (gBedroomAC, gAllAC) ["Control", "Power"] {channel="daikin:ac_unit:192_168_1_91:power"}
Number:Temperature DaikinHaloSettemp "Hőfok" <temperature> (gBedroomAC, gGAHaloAC) ["Setpoint", "Temperature"] {channel="daikin:ac_unit:192_168_1_91:settemp", ga="thermostatTemperatureSetpoint"}
Number:Temperature DaikinHaloIndoortemp "Szoba Hőmérséklet" <temperature> (gBedroomAC, gGAHaloAC) ["Measurement", "Temperature"] {channel="daikin:ac_unit:192_168_1_91:indoortemp", ga="thermostatTemperatureAmbient"}
Number:Temperature DaikinHaloOutdoortemp "Terasz Hőmérséklet" <temperature> (gTerraceSensor) ["Measurement", "Temperature"] {channel="daikin:ac_unit:192_168_1_91:outdoortemp"}
String DaikinHaloMode "Mód" (gBedroomAC, gGAHaloAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:mode", ga="thermostatMode"}
// String DaikinHaloHomekitmode "Homekit mód" (gBedroomAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:homekitmode"}
String DaikinHaloFanspeed "Ventillátor erősség" <fan> (gBedroomAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:fanspeed"}
String DaikinHaloFandir "Ventillátor irány" <flow> (gBedroomAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:fandir"}
// String DaikinHaloSpecialmode "Speciális mód" (gBedroomAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:specialmode"}
Switch DaikinHaloSpecialmodePowerful "Erőteljes mód" (gBedroomAC) ["Control"] {channel="daikin:ac_unit:192_168_1_91:specialmode-powerful"}
Number:Energy DaikinHaloEnergycoolingtoday "Háló Klíma Napi Fogyasztás" <energy> (gBedroomAC) ["Status", "Power"] {channel="daikin:ac_unit:192_168_1_91:energycoolingtoday"}
I Think I should add somehow a ga= tag to the DaikinHaloPower Item to be able to switch it on / off but I’m not sure what tag should I use for it.
