Nognog
(Daniel N.)
January 8, 2020, 7:03pm
41
Hello together,
i have installed a Hyperion server on another PI4, Hyperion Binding 2.5 on Openhab 2.5.
I can control Hyperion, but I have a problem that the clear-channel does not work. I tried “50” and “ALL” both commands don’t work
things:
Thing hyperion:serverV1:nextcloudpi "Hyperion Server" @ "Wohnzimmer"[ host="myip-adress", port=19444, priority=50, poll_frequency=15 ]
items:
String whz_hyperion_clear "Prio löschen" (gHyper) {channel="hyperion:serverV1:nextcloudpi:clear"}
I get no error in Log
If I adjust the color change, the brightness … everything works
Nears
(Nears)
April 29, 2020, 7:09pm
42
Easy installation is possible by using pre-compiled packages from github like this:
wget https://github.com/hyperion-project/hyperion.ng/releases/download/2.0.0-alpha.5/Hyperion-2.0.0-alpha.5-Linux-armv7hf-rpi.deb
dpkg -i ./Hyperion-2.0.0-alpha.5-Linux-armv7hf-rpi.deb
wars
(Ward)
April 29, 2020, 8:33pm
43
Hi, thanks for the info.
Last week I found this post on the Hyperion forum. I installed Hyperion NG a couple of days ago and it’s working fine on my PI, with LibreElec.
I did not tried NG with the Hyperion binding, I think it can be controlled with simple http calls also?
I just saw the binding also supports kodichecker
, but I don’t find this option in the Webgui of Hyperion NG
poeppe
(poeppe)
July 15, 2020, 9:10pm
44
so in case somebody is still looking for a list of the default effects:
Selection item=Hyperion_Effect mappings=[
'Cinema brighten lights'='Cinema brighten lights',
'Cinema dim lights'='Cinema dim lights',
'Knight rider'='Knight rider',
'Blue mood blobs'='Blue mood blobs',
'Cold mood blobs'='Cold mood blobs',
'Full color mood blobs'='Full color mood blobs',
'Green mood blobs'='Green mood blobs',
'Red mood blobs'='Red mood blobs',
'Warm mood blobs'='Warm mood blobs',
'Police Lights Single'='Police Lights Single',
'Police Lights Solid'='Police Lights Solid',
'Rainbow mood'='Rainbow mood',
'Rainbow swirl fast'='Rainbow swirl fast',
'Rainbow swirl'='Rainbow swirl',
'Running dots'='Running dots',
'System Shutdown'='System Shutdown',
'Snake'='Snake',
'Sparks Color'='Sparks Color',
'Sparks'='Sparks',
'Strobe blue'='Strobe blue',
'Strobe Raspbmc'='Strobe Raspbmc',
'Strobe white'='Strobe white',
'Color traces'='Color traces',
'X-Mas'='X-Mas'
I also created a PR to add it to the readme: https://github.com/openhab/openhab-addons/pull/8135
wars
(Ward)
October 26, 2020, 12:00pm
45
In Hyperion NG you can define multiple instances. Is it possible to add this to the binding? So I can start/stop an extra instance?
eric1905
(Eric)
March 22, 2021, 8:15pm
46
I am struggling a little bit with hyperion (ng)
I am using it as a USB Grabber for my TV. But I also want to use some effects when TV is off.
So my default priority is USB Grabber with prio code 100.
When I now change the effect in openhab there is one other entry in hyperion ng with prio 240 for the effect. But this effect is not selected as a source in hyperion ng. It stays at the source of my grabber.
Is there a possibility to say: When HyperionEffect changes select this priority directly as a source or is there the possibility to say: change effect and then a rule when effect is changed that i can say: priority 240 is now my source for the leds?
Nears
(Nears)
April 17, 2021, 6:42pm
47
In Hyperion a lower number means a higher priority, so if you set your effect to e.g. prio 50 it should overrule the USB grabber and your effect should be showing up.
eric1905
(Eric)
April 18, 2021, 8:28pm
48
But there is no channel where I can specify which priority my effect has or am I wrong?
Nears
(Nears)
April 18, 2021, 8:53pm
49
Yes you can. You define the priority of all openhab requests in the thing definition, e.g. example from above
Thing hyperion:serverV1:nextcloudpi “Hyperion Server” @ “Wohnzimmer”[ host=“myip-adress”, port=19444, priority=50, poll_frequency=15 ]
