persistence = jpa , mysql , jdbc-mysql,rrd4j,mapdb
when i edit these lines , for example when i change
ui = basic,paper,habpanel,habmin
to
habmin did not remove in my ui panel.
and i have this problem with bindings and i cant remove or install a new one… what should i do?
Installing and deinstalling other bindings ( not set in addons.cfg) should have been possible ( at least such works for me).
What do the logs say when you try to install a different addon?
