I am trying to deserialize some JSON data received from the bridge binding that I am working on. Its JSON data structure is as follows…
{"devices":[
"CURRENT_TEMPERATURE":"255.255",
"STAT_MODE":
"MANUAL_OFF":true,
"TIMECLOCK":true
"TIMER":false,
"device":"Watering System"
I am trying to parse it with GSON @SerializedName annotations. The code is shown below. The problem lies with the deep nesting of the JSON structure resp. the Java classes. To be specific with the inner-inner class StatMode. When I run the createJsonResponse method, it does not throw any exceptions, but when I try to access the StatMode class via its property getter (not shown), it causes a crash.
I think the parsing is working, but I don’t know if the classes are being created correctly, or how to access them. I think it could be due to the static keywords perhaps??
class JsonResponse {
@SerializedName("devices")
private List<DeviceInfo> deviceInfos;
static class DeviceInfo {
@SerializedName("device")
private String deviceName;
@SerializedName("CURRENT_TEMPERATURE")
private BigDecimal currentTemperature;
@SerializedName("TIMER")
private Boolean timerOn;
@SerializedName("STAT_MODE")
private StatMode statMode;
static class StatMode {
@SerializedName("MANUAL_OFF")
private Boolean manualoff;
@SerializedName("TIMECLOCK")
private Boolean thermostat;
// property getter methods..
static @Nullable JsonResponse createJsonResponse(String response) {
try {
Gson gson = new Gson();
return gson.fromJson(response, JsonResponse.class);
} catch (Exception e) {
throw new IllegalStateException(e.getMessage(), e);
