I need help for configuring Openhab! IT-Specialist, but openhab novice
who can help me for configuring my Powerconsumption analysis, that is very high
i have buy following things:
  1. a rasperry PI with openhab version 4.2.1
  2. a adapter Protoss-PE11 RS485<->Ethernet
  3. 4 Orno Single Phase Energy Meter OR-WE-525
All elements are installed correctly with fixed ip-address and i have all data for connecting
the german vendor don’t response on phone or mail, i think he is not able to assist me
Is there in Germany specialists for Openhab, for expand my smart home over the Powerconsumption
Thanks for help
Claude Greiner
cgreiner@cgcs.de
I know @mstormi is in Germany. There may be others too who can help. Or if you want to do it yourself, although probably much slower, we can help you here.
I want help and Need Assistance to be able to become the wanted functions and may be more possibilities! How can i contact @mstormi
You could send him a private message or post more details here.
Please don’t send a private message. Post more information here, in case someone else can help you.
Markus will see that he’s been tagged in this conversation. If he’s in a position to assist you, he’ll offer to do so himself.
@mstormi will not Assist me! Search help!
What do you Need as more information?
The challenge is to configure openHAB To Analyse the values coming over the Interface
If so, please stop tagging him. Some folks dislike being tagged repeatedly in discussions, because it sends a notification every time.
When you started your post, there should have been a template for you to fill in. It either didn’t show up or you deleted it.
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: what OS is used and which version
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version:
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
I am not in a position to help you, as I live in Canada. But more than that, it’s unclear what your problem is beyond “Powerconsumption”.
Since you’re an IT specialist, what do you think when a user says, “a program on my computer isn’t working”? I assume that you ask them a series of questions in order to find out what their actual problem is. You need to do the same for yourself, so that people here can try to help you.
I don’t need instructions, rpwong, but concrete support in configuring the above-mentioned devices, i am novice in openhab and smart home, but i am a old and lovely retired man, that will be accepted all help from this little world, may be there is anybody that had a remote tool and want to assist me and become gratulations by success!
great regards from germany to Canada!
So start by telling us how did you configure openhab?
Did you install the modbus binding?
Where you able to get it connected to your Protoss-PE11 RS485?
are you getting data into openhab
Have you reviewed all the parts of openhab to understand terms like things binding items and how they all work?
Understand everyone on this forum including those who have responded to you are volunteers there is not remote tool for us to log into your system and configure it for you.
There are companies that you can contract with pay $$ to and they will happily come to you place and will actually set up custom home automation solutions for you.
But this is forum is all volunteers who do home automation as a hobby and help where they can.
start out by reviewing the modbus binding there are many links in its documentation once you have done that and at least gotten to a good understanding of how Openhab works and all of its components we may be able to add more advice and guidance.
I have send you a PM.
Hi Claude,
I’ve worked with OpenHAB integrations for various clients over the years , and I’m happy to help.
Let’s connect and see if I can get you up and running with your energy monitoring.
You can reach out to me on my email here
Colin
i am also a “just a old men” retired and completly novice in openhab
but i will become remote help in germany begin september 2024!
first, i will analyze my high energy costs and then seen what i can do with openhab!
Before the recommandation for openhab, i had FHEM for smarthome!
Thanks for your answer!
