iBox2, milight, white LED stripe
I try to use openhab 2.4 with an iBox 2 an a white LED stripe.
The bridge is found, but I am not able to configure the light.
The mi-light App works an the remote controller to. It is only white and the stripe is integrated in a funiture.
At the momet I use Paper UI.
Any Ideas, thanks in advance
Jan
Please post the content of your things and items file. Also provide more info on the LED stripe used or a link to reference.
I could be wrong but I remember seeing in the milight documents that the binding does not support LED Strips only the globes. If that is the case, this binding works with the LED strip controllers that milight make.
