I want to control my rollershutters via iCalendar binding. What works nicely are UP and DOWN commands like this:
BEGIN:Rollo_EG_Wohnen_Ost_Level:DOWN
This also generates these entries in events.log
2021-09-30 19:25:00.070 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Rollo_EG_Wohnen_Ost_Level' received command DOWN
2021-09-30 19:25:00.072 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Rollo_EG_Wohnen_Ost_Level' predicted to become DOWN
2021-09-30 19:25:00.075 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Rollo_EG_Wohnen_Ost_Level' changed from 0 to 100
What does not work is to pass an actual level that the item should move to such as
BEGIN:Rollo_DG_Schlafen_Level:76
I would expect the rollershutter to move to position 76% closed. But instead simply nothing happens. No entry in openhab.log is generated, events.log shows only the following line. The expected “predicted to become” and “changed from … to …” are missing:
2021-10-04 06:45:00.096 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Rollo_DG_Schlafen_Level' received command 76
Any idea what I need to do differently to move the rollershutter to a specific level through iCalendar binding?
