i´m currently making a oH 1.8.3 to oH 2 migration and had first look on the iCloud binding.
As we´re only using iOS devices this is a pretty nice feature to work with.
But there´s some part that´s not working.
Text item=fbUserB valuecolor=[OPEN="green", CLOSED="gray"]
Text item=iPUserB_BatteryStatus
Text item=iPUserB_BatteryLevel
Switch item=iPUserB_FindMyPhone mappings=[ ON="Suchen!" ]
Text item=iPUserB_Accuracy
Text item=iPUserB_LastUpdate
Mapview item=iPUserB_Location
Switch item=iPUserB_Refresh mappings=[ REFRESH='Aktualisieren' ]
When using the FindMyPhone button i get the following error in my logfile
2018-07-15 12:15:39.530 [ome.event.ItemCommandEvent] - Item 'iPUserB_FindMyPhone' received command ON
2018-07-15 12:15:40.988 [WARN ] [g.icloud.handler.ICloudDeviceHandler] - Unable to execute find my device request
java.io.IOException: Server returned HTTP response code: 500 for URL: https://fmipmobile.icloud.com/fmipservice/device/openhab@mydomain.com/playSound
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1894) [?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492) [?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263) [?:?]
at org.openhab.binding.icloud.internal.Connection.getResponse(Connection.java:107) [236:org.openhab.binding.icloud:2.3.0]
at org.openhab.binding.icloud.internal.Connection.postRequest(Connection.java:97) [236:org.openhab.binding.icloud:2.3.0]
at org.openhab.binding.icloud.internal.Connection.findMyDevice(Connection.java:69) [236:org.openhab.binding.icloud:2.3.0]
at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.findMyDevice(ICloudAccountBridgeHandler.java:107) [236:org.openhab.binding.icloud:2.3.0]
at org.openhab.binding.icloud.handler.ICloudDeviceHandler.handleCommand(ICloudDeviceHandler.java:95) [236:org.openhab.binding.icloud:2.3.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at com.sun.proxy.$Proxy135.handleCommand(Unknown Source) [236:org.openhab.binding.icloud:2.3.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
2018-07-15 12:15:41.023 [vent.ItemStateChangedEvent] - iPUserB_FindMyPhone changed from NULL to OFF
Yes the username/password combination is correct.
Otherwise oH wouldn´t be able to get the informations from all other channels.
It´s just this one channel that isn´t working.
For example: 2018-07-16 19:12:10.756 [vent.ItemStateChangedEvent] - iPUserB_Accuracy changed from 24.0 to 48.0
@rlkoshak: Just for you i “just edited” the documentation.
It wasn´t just editing a textfile.
You need a Github account
You need to fork (forks belong in the kitchen)
You need to make the changes
You need to create Pull request
These are four steps to edit a documentation. I don´t think that normal users will create a GitHub Account just to change the documentation. But you already heard that, i know…
Back to the problem…
Is this feature not supported anymore?
Sure i did…
That´s because all other channels of this binding works.
Only the ‘{channel=“icloud:device:openHAB:iPUserB:findMyPhone”, autoupdate=“false”}’ isn´t working.
All other channels like Battery Status/Level, Force Update, Location, Accucary and Last Update are working fine.
Even without ‘autoupdate=“false”’ i get the http 500 error.
Asking in another direction: What should the ‘findMyPhone’ channel do?
I just made a quick test.
Without the Find my Phone option you´re not able to receive any data from iCloud.
The option is required to get the data for all of the channels.
To answer that question again:
Yes, i did because otherwise i wouldn´t receive any data from the device at all.
No, the feature “Find my Phone” is required for all channels of this binding.
That could be the problem.
I´m using a dedicated openHAB iCloud with family share.
The iOS devices are all linked to a iCloud account for the owner.
So there´s no account with all devices, just the family share.
You shouldn´t start getting personal and don´t say things from above like you did there.
You don´t know me.
But thanks that you didn´t even noticed that i made a change and created a pull request.
But hey i´m just the user saying the doc is shit and you´re the high qualified developer…
I guess we are both making assumptions. I’m not a developer on OH. I spend my time contributing to the project by helping users on this forum, mostly with Rules. I don’t do much with the Docs and I don’t do anything with the code. So I would’t have seen your PR.
And I said “like you” because you made it clear you are not a developer. I wouldn’t expect a non-developer to start out by making sweeping changes to the OH docs. That requires a lot more coordination and effort than could be expected from any new contributor, let alone a non-developer.
I guess I missed the day in class where they taught that using the word “you” is an insult.
I need to fork the doc before otherwise i´m not able to make changes: You’re editing a file in a project you don’t have write access to. Submitting a change to this file will write it to a new branch in your fork bredmich/openhab2-addons, so you can send a pull request.
So no, it´s not just editing a page from the docs…
Get back to real question: Is the channel findMyPhone only usable when the iOS devices are directly attached to the account used for the Bridge.
Can I make a suggestion, not sure if you’ve tried this yet but here goes.
Try breaking this problem down into smaller chunks, build up to your end game. Have you reduced your configuration down to a single device and tested whether that works or not.
I have two iPhones, both are on separate accounts and they are working fine for me. I used the example in the docs to complete my configuration. You could have found genuine bug/issue or your trying to do something outside of the original scope the developer had in mind.
I am able to play sounds on my wife’s phone using the native iOS app, as we are using a family share. I am not able to find her phone using the openhab iCloud binding. I can read her battery status, her location, but finding the phone only works on my own device.
