Hi
I changed the refresh from 5 minutes to 15 minutes in the binding, and now the items do not refresh anymore.
With 5 it is all OK, but I use it for 7 devices, that might be a bit too much and I don’t need that granularity.
15 or 30 minutes is more than enough, but doesn’t work
Here is my config
Bridge icloud:account:karl [appleId=“xxx”, password=“xxx”, refreshTimeInMinutes=15]
Thing device iPhoneKarl “iPhone Karl” @ “World” [deviceId=“xxx”]
Thing device iPadKarl “iPad Karl” @ “World” [deviceId=“xxx”]
And for the items
String iPhoneKarl_BatteryStatus “Battery Status [%s]” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:batteryStatus”}
Number iPhoneKarl_BatteryLevel “Battery Level [%.0f %%]” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:batteryLevel”}
Switch iPhoneKarl_FindMyPhone “Trigger Find My iPhone” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:findMyPhone”}
Location iPhoneKarl_Location “Coordinates” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:location”}
Number iPhoneKarl_LocationAccuracy “Coordinates Accuracy [%.0f m]” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:locationAccuracy”}
DateTime iPhoneKarl_LocationLastUpdate “Last Update [%1$td.%1$tm.%1$tY, %1$tH:%1$tM]” (iCloud_Group) {channel=“icloud:device:karl:iPhoneKarl:locationLastUpdate”}
Switch iPhoneKarl_Refresh “Refresh”
As a side question, I added a Switch to force a refresh, linked to a rule
rule "Button Refresh Karl iCloud"
Item iPhoneKarl_Refresh changed to ON
postUpdate(iPhoneKarl_BatteryStatus, REFRESH)
postUpdate(iPhoneKarl_Refresh, OFF)
In the description for the binding they mention we can send a REFRESH to any channel, but then I got
2018-02-16 15:19:43.137 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Button Refresh Karl iCloud’: The name ‘REFRESH’ cannot be resolved to an item or type; line 39, column 46, length 7
2018-02-16 15:19:42.938 [ome.event.ItemCommandEvent] - Item ‘iPhoneKarl_Refresh’ received command ON
2018-02-16 15:19:42.962 [vent.ItemStateChangedEvent] - iPhoneKarl_Refresh changed from NULL to ON
Thanks for feedback
