Look at Design Pattern: Working with Groups in Rules.
There might be some useful info in Generic Presence Detection.
But one thing you will run into I suspect is that in order to write good Rules that don’t require changing them to add new phones, you will need to get a bit of understanding for Rules.
At a high level, put all the location Items in a Group:Location Group.
Trigger the Rule with Member of PhoneLocations changed
Use a map/reduce to get the phone distance that is furthest from home. Then update and log as approraite.
val PointType home_location = new PointType(new DecimalType(xx.05135920063), new DecimalType(xx.6613793811))
rule "allPhone_Rules"
val furthest = PhoneLocations.members.map[ state as PointType].reduce[max=0, phone |
distance = phone.distanceFrom(home_location)
if(distance > max) max = distance
if(furthest < 200) {
iCloud_Group.postUpdate(ON)
logInfo("allPhone", "home!")
else {
iCloud_Grouop.postUpdate(OFF)
logInfo("allPhone", "away!")
I’m not 100% certain I have the syntax right on the map/reduce but it should be pretty close.
