iCloud Find My Phone not working
Has anyone else noticed that the Find My Phone channel doesn’t work anymore?
Everything else works. Location etc
I get this error when trying Find My Phone
[ERROR] [AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.icloud.internal.handler.ICloudDeviceHandler@72d0d014': Retry finally failed.
org.openhab.binding.icloud.internal.RetryException: Retry finally failed.
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.callApiWithRetryAndExceptionHandling(ICloudAccountBridgeHandler.java:216) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.findMyDevice(ICloudAccountBridgeHandler.java:290) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudDeviceHandler.handleCommand(ICloudDeviceHandler.java:145) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) ~[?:?]
	at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) ~[?:?]
	at jdk.proxy53922.$Proxy54119.handleCommand(Unknown Source) ~[?:?]
	at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:85) ~[?:?]
	at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) ~[?:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
Caused by: org.openhab.binding.icloud.internal.ICloudApiResponseException: Request https://p114-fmipweb.icloud.com:443/fmipservice/client/web/playSound failed with 500.
	at org.openhab.binding.icloud.internal.ICloudSession.request(ICloudSession.java:148) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudSession.post(ICloudSession.java:98) ~[?:?]
	at org.openhab.binding.icloud.internal.FindMyIPhoneServiceManager.playSound(FindMyIPhoneServiceManager.java:77) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$5(ICloudAccountBridgeHandler.java:294) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.callApiWithRetryAndExceptionHandling(ICloudAccountBridgeHandler.java:185) ~[?:?]
	... 21 more```
I’m having the same issue and have been for a few months on 4.0.3.
Same here. I haven’t used it in a while but it seems to have stopped working a few months ago. Presumably something has changed on the server side?
Same here. Even in 4.1.0.M5 no “Find my Phone”… Server code 500.
Also just tried to get the Find My Phone feature working but getting only this error. Is there anyone for whom it still works, or is it generally broken? I am on OH 4.1.0. Location and battery status seem to be working, only Find My Phone does not.
2024-01-08 20:21:32.308 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.icloud.internal.handler.ICloudDeviceHandler@2ff92bd3': Retry finally failed.
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.callApiWithRetryAndExceptionHandling(ICloudAccountBridgeHandler.java:213) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.findMyDevice(ICloudAccountBridgeHandler.java:287) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
	at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
	at jdk.proxy45186.$Proxy45306.handleCommand(Unknown Source) [?:?]
	at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:95) [bundleFile:?]
	at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: org.openhab.binding.icloud.internal.ICloudApiResponseException: Request https://p126-fmipweb.icloud.com:443/fmipservice/client/web/playSound failed with 500.
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$5(ICloudAccountBridgeHandler.java:291) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.callApiWithRetryAndExceptionHandling(ICloudAccountBridgeHandler.java:182) ~[?:?]
	... 21 more
I created a new issue for this:
In the current openHAB version it works again, thank you very much for fixing it!
