yeah that could be the case as well. I’ll see if I can actively trigger the error so I can investigate once I find some time in my agenda
Please note when using my snapshot build, that it’s not checking if the certificate downloaded is a valid certificate. In case of a man in the middle attack this will leave you exposed s well as your credentials. I’m gonna see if I can validate the certificate to get the pull request approved, but I thought it would be good to let users know they’re running my snapshot with a security risk. Use at your own risk
The installed seems to be your snapshot. And didn’t have a remove button for that. remove is only at add-ons, and there iCloud is not installed
Thought openhab would know it’s the same but only newer version .
For people (like me) following this tread and quickly want to fix the broken icloud binding without reading the complete thread, do these steps:
https://community.openhab.org/t/icloud-ssl-issue-again/79182/115
with this jar:
https://community.openhab.org/t/icloud-ssl-issue-again/79182/165
Thanks Tobias worked for me.
Automatically downloading and thereby accepting the TLS certificate is not a good idea. As you already this setup is vulnerable to MITM attacks.
I saw that the binding includes the server certificate but not Apples CA certificate. So when Apple issues a new certificate things broke. If it is true that Apple does not change his CA certificate often it would be enough to include this in the binding.
To test this a created a new jar where I replaced the former server certificate with Apple current CA certificate:
First tests look good. Fell free to test it.
Hello all,
works out for me and sounds sensible.
Best regards,
Willi
Thanks for your input! I agree with the security hole that was in the previous snapshots, I removed these from google drive. I updated the code today to verify the certificate against the certificate chain, up to the root CA certificate (there’s an Apple Server CA that expires years before the root CA certificate).
Did you use the server CA or the root CA?
My latest snapshot (including certificate verification) can be found here: https://drive.google.com/file/d/10227PoeE4Dh4ZF2PCTH9MyMDeH_FKsyS/view?usp=sharing
Works for me locally
I’ve installed this snapshot on openhab 2.4.0 and am getting the following message:
bundle org.eclipse.smarthome.io.net:0.10.0.oh240 (118)[org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManager(122)] : The addTlsCertificateProvider method has thrown an exception
java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/net/http/TrustAllTrustMananger
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.net.http.TrustAllTrustMananger cannot be found by org.openhab.binding.icloud_2.5.2.202001301255
Looks like I’m missing a dependency but not sure how to install it. Appreciate any advice.
I get the error when using maihacke’s snapshot. If I use yours nothing happens in openhab. I get no error messages and none of my apple devices work. The jar is in the ‘addons’ folder and when I do a 'bundle:list: in the console the jar is listed however the state is ‘waiting’ I’ve rebooted the system and left it alone for around 20 minutes and the binding is still waiting.
Can you please try this snapshot? It turns out that we can simply get this binding more stable by using the root certificate (thanks for the pointer @maihacke!!!) , instead of the server certificate. I’ve tried this snapshot, and it works locally. It’s a much simpler change actually (see https://github.com/openhab/openhab-addons/pull/6948 for the new pull request)
Thanks Hawkeye! It worked!
Would be good if more people could check this latest snapshot; it’s already been approved for merging but would be good to hear if it’s working for more people before actually merging
It looks like it is working for me. openHAB2.5.2 stable plus iCloud binding snapshot posted. It doesn’t throw exceptions and connects successfully.
tested it on one 2.4 and one 2.5 installation and it works! Thanks.
in a first attempt I forgot to change the owner of the jar file to openhab after puting it into the /user/share/openhab2/addons folder on my rpi (just in case someone else is wondering why the addon is not being installed as well )
Being a newbie to this, I cant make this work on a pi, i have changed the owner to openhab, rebooted but i still get errors. I am not sure i have the correct jar file, bundle:list report :-
2.5.2.202002010827
Have i got the correct jar file ?
did you follow there steps?
- Donwload the jar file from google drive
- make sure that in /user/share/openhab/addons is not an old jar file (rm it otherwise)
- copy the file to /user/share/openhab/addons
- chown openhab:openhab icouldFileName.jar (maybe it is allready check with “ls -la”)
- start the console with: “sudo openhab-cli console”
- bundle:list and note the number from the icloud addon
- bundle:uninstall “number of the addon”
- with command logout quit the console
- sudo service stop openhab2
- sudo service start openhab2
Hi, thanks for that unfortunately I had done all that, twice !
error im getting seems to be something about a certificate
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Any idea what i have forgotten ?
