gson is installed, right?
bundle:install https://repo1.maven.org/maven2/com/google/code/gson/gson/2.8.5/gson-2.8.5.jar
Great thanks didnât see that requirement Having installed that everything now works
Thanks for the great work.
Everything now working flawlessly.
Still not working reliable. I have installed the 2.5.2 Snapshot and after restarting it works for some hours. But then it is not updating datas anymore despite being shown as online. Disabling and enabling the device or ICloud it stays in the INITIALIZING mode and the Log Viewer shows:
[WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing âicloud:device:xxxxxx:xxxxxxâ takes more than 5000ms. Anybody with the same issue and/or idea?
Didn´t had any errors today after installing this build!
Thanks for your work.
Installed, restarted openHAB and my iCloud connection returned without a single error in the log so far. Awesome work guys!
Working good for me, thank you!
Same here! Working great:-)
I had installed the new JAR file with the updated certificate about 1 or 2 weeks ago and it worked for me too. However, suddenly it dropped back to not working again and keeps throwing this error every 5 minutes again. This happens without me having re-installed or rebooted anything. How is this possible?
Error message:
Unable to refresh device data
java.io.IOException: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:91) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:72) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:95) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:152) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:685) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:250) ~[?:?]
... 16 more
Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1521) ~[?:1.8.0_222]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:528) ~[?:1.8.0_222]
at sun.security.ssl.SSLEngineImpl.writeAppRecord(SSLEngineImpl.java:1197) ~[?:1.8.0_222]
at sun.security.ssl.SSLEngineImpl.wrap(SSLEngineImpl.java:1165) ~[?:1.8.0_222]
at javax.net.ssl.SSLEngine.wrap(SSLEngine.java:509) ~[?:1.8.0_222]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:891) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:378) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.lambda$fill$1(SslConnection.java:669) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) ~[?:?]
... 1 more
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_222]
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1709) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:318) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_222]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1654) ~[?:1.8.0_222]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:233) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:970) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:967) ~[?:1.8.0_222]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_222]
at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1459) ~[?:1.8.0_222]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:526) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:128) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:154) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) ~[?:?]
... 1 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:1.8.0_222]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:1.8.0_222]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_222]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:327) ~[?:1.8.0_222]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:279) ~[?:1.8.0_222]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:144) ~[?:1.8.0_222]
at org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManagerImpl.checkServerTrusted(ExtensibleTrustManagerImpl.java:121) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1636) ~[?:1.8.0_222]
... 1 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_222]
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_222]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_222]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:1.8.0_222]
... 1 more
The binding version I am using is 2.5.2.202001211144.
The binding that is linked in this post is actually the same version: 2.5.2.202001211144 and throws the same error immediately.
This is the link in this post:
Thatâs what I did.
The current version is 2.5.2.202002010827
and can be installed with this jar: https://drive.google.com/file/d/1uevf3Krw_GrNHYd2CmJAbMBkk2-yRUnz/view
You need to delete the old .jar in your addons folder and wait for openHAB to remove the binding.
Just have a look at your logviewer and wait for all iCloud devices to be offline because the handler is missing,
Then place the new .jar file into your addons folder.
The version of the .jar file itself is still 2.5.2, please don´t mix with older builds.
Thank you. Itâs working now for me.
Works here as well.
Works fine after update to 2.5.2.202002010827. Thanks!
