Is it possible that the Certificate changed again?
I have noticed I am getting the following errors now.
LOG
2019-12-31 04:13:20.789 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:88) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:69) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:88) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:145) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_201]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_201]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_201]
Caused by: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:685) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:250) ~[?:?]
... 16 more
Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1521) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:528) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.writeAppRecord(SSLEngineImpl.java:1197) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.wrap(SSLEngineImpl.java:1165) ~[?:1.8.0_201]
at javax.net.ssl.SSLEngine.wrap(SSLEngine.java:509) ~[?:1.8.0_201]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:891) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:378) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.lambda$fill$1(SslConnection.java:669) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) ~[?:?]
... 1 more
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1709) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:318) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_201]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_201]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:970) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:967) ~[?:1.8.0_201]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1459) ~[?:1.8.0_201]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:526) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:128) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:154) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) ~[?:?]
... 1 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:1.8.0_201]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:1.8.0_201]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:281) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:136) ~[?:1.8.0_201]
at org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManagerImpl.checkServerTrusted(ExtensibleTrustManagerImpl.java:121) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1626) ~[?:1.8.0_201]
... 1 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_201]
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_201]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_201]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:1.8.0_201]
... 1 more
I have been upgrading my Debian based OS machines over the break so it could be a local OS system update issue as I noted that one of the upgrades mentioned CA certificates being updated.
Anyone throw some light on what the errors are pointing at please?
Paul
Itās exactly the same issue I had.
After upgrading to 2.5 it works fine.
I am on version 2.5.
I guess this is not widespread, I will look for a more localised issue.
Paul
I tried all the fixes but nothing worked. Eventually i noticed that i actually have TWO icloud bindings active but nothing in the openhab2-addons folder. I have no clue how this happened, but here is how i fixed it:
- Uninstall the iCloud binding from PaperUI.
- Go to Karaf and
bundle:list | grep -i icloud
- Make note of the bundle id on the left.
bundle:uninstall XXX
and replace XXX with the id of your iCloud Binding bundle.- Install iCloud binding from PaperUI again. My account went online immediately.
This is failing again for me on 2.5 as of this morning. Anybody else seeing it?
+1 - same here
@theiding @frankie.delure
Unfortunately the cert changed again. I have managed to get it working again by a quick fix.
I will provide a link to the updated jar as soon as the build finishes.
This is not really a good thing that the cert is hard coded in the binding, I will try to find a way to get over with it, and manage the cert automaticallyā¦
Try this version
I tried that build and still getting the same error. Is there something else I need to do to get it to work?
What is your error exactly?
If still SSLEngine problem, make sure your previous version uninstalled, restart OH, you might also try clearing the cacheā¦
For me that version works and others also reported that it solved their issueā¦
Hi!
Same problem sadly - still SSL problem.
Tried clearing cache, restarting OH, previous version gone.
Running version 2.5.2.202001211636
Any other ideas?
Thanks for all your work!
Same issue here. Also tried clearing cache etc.
@amaino @Hobohome
Yes I know why⦠Because that version I linked somehow doesnāt contain the latest changes I have made⦠I forgot to check this and trusted Jenkins
And I donāt know why but I canāt find a version in Jenkins which contains these updates.
Here is a link to my local build, this should work:
https://drive.google.com/open?id=113xzmCqccg7Wf7ATl0d_xWqFEL4nNkt1
Is it possible to get the working update somehow via the normal openhab update mechanisms, i.e. w/o downloading and installing that JAR?
Worked - Thanks very much!
When I first updated with the jar from the Google Drive link it still showed SSL error, after about 5 mins it worked. Thanks
It went offline again after a few minutes with an SSL error
What happens if you restart the bundle? It will come back online?
I hope that these fixes will be available in the next release.
openHAB doesnāt distribute the bindings independent from itās core package, so āautomaticallyā the bindings will get updated when a new openHAB update is out (ie.: You canāt select a binding version in PaperUI to useā¦").
