Dear Community,
Apologies if this question has been asked and answered. I did review related threads but could not quite get what I was after, hence this post.
Queries:
- Openhab HABPanel UI provide “code”, “Setting” and “Preview”. Am looking for a more robust IDE for the Code section, something with hints, autocomplete, syntax checking - maybe even WYSIWYG. What do you typically use?
- Is the above possible using VSCode - to develop standalone, and then simply paste the final code into the UI ?
- Chrome periodically hangs when coding widgets - have you experienced ? if yes - whats the root cause and solution ?
regards
