But surely there is some double, some are already quite old - some certainly still in the clock state from 2018 when I started with zero experience.
As always a prioritization and time problem - :wink: time and desire to come over and help - alternatively, I can send you the VPN access :wink:
For new rules I already rely on Copilot to have less dublicates.
But for example I got at least 100 of those two:
rule "batteriewarnung-62"
//Batteriewarnung KiZi 2 TM
   Item TM_KiZi_2_NiedrigerBatteriestatus changed to ON
    sendNotification("xxx@icloud.com", "🔋 Die Batterie im Thermometer im KiZi 2 ist leer (Zwei AAA-Batterien).", "battery", "Battery Tag", "Da Hoam", "KiZi_2-bat-id-5", null, null, null, null, null)
    sendNotification("xxx@gmx.de", "🔋 Die Batterie im Thermometer im KiZi 2 ist leer (Zwei AAA-Batterien).", "battery", "Battery Tag", "Da Hoam", "KiZi_2-bat-id-5", null, null, null, null, null)
rule "batteriewarnung-63"
//Batteriewarnung Bewegungsmelder vor EZ
   Item BW_EG_vEZ_Batterie changed
    if (BW_EG_vEZ_Batterie.state instanceof Number && (BW_EG_vEZ_Batterie.state as Number) < 10) {
        sendNotification("xxx@icloud.com", "🔋 Die Batterie im Bewegungsmelder vorm Esszimmer ist leer (Eine CR2450-Batterie).", "battery", "Battery Tag", "Da Hoam", "Treppenhaus-bat-id-2", null, null, null, null, null)
        sendNotification("xxx@gmx.de", "🔋 Die Batterie im Bewegungsmelder vorm Esszimmer ist leer (Eine CR2450-Batterie).", "battery", "Battery Tag", "Da Hoam", "Treppenhaus-bat-id-2", null, null, null, null, null)
or those for my motion sensors:
rule "eingang_treppenhaus-2"
//Motiontimer aus falls waehrend Laufzeit der Bewegungsmelder wieder angeht
  Item BW_TH_vWZ changed
    if (motion_timer_one !== null && BW_TH_vWZ.state==ON) {
      motion_timer_one.cancel
      motion_timer_one = null //Abbruch Timer
    else if(BW_TH_vWZ.state!=ON && Lampe_Treppenhaus_WZ_Schalter.state==ON) {
    motion_timer_one = createTimer(now.plusMinutes(2), [|
            Lampe_Treppenhaus_WZ_Schalter.sendCommand(OFF)
or those for every room:
rule "buero-8"
//Heizung Buero wenn Buerofenster offen/geschlossen
    Item Buerofenster changed
if (Buerofenster.state== ON && Allgemeine_Heizungssteuerung.state != '3' && Heizkoerper_Buero_BoostMode.state==ON){
    Heizkoerper_Buero_BoostMode.sendCommand(OFF)
    Buero_Temperatur.postUpdate(Heizkoerper_Buero_SetTemperature.state)
    Heizkoerper_Buero_SetTemperature.sendCommand((Window_open_Temp.state as Number).floatValue)
else if (Buerofenster.state== ON && Allgemeine_Heizungssteuerung.state != '3' && Heizkoerper_Buero_BoostMode.state!=ON){
else if (Buerofenster.state== OFF && Allgemeine_Heizungssteuerung.state != '3'){
	Heizkoerper_Buero_SetTemperature.sendCommand((Buero_Temperatur.state as Number).floatValue)
and so on and on…
very much potential to optimize, but lack of time and the bigger problem the WAF - everytime something does not work as expected it drops and makes future purchases harder :slight_smile:
That only works for thermostats that are native to Resideo. Honeywell has a second (older) app called Total Comfort Connect. It also provides an API but there is not a binding for it currently.
I actually really like the thermostats I have so I won’t swap them unless the app ever gets shuttered. But maybe I’ll try to write a binding for 5.0.
There indeed is a lot room for improvement.
You could group those items and work with triggeringItem on group changes. The are some good posts around that topic….
File Explorer and editor to edit all files like item files, sitemap, things and so on from the config folder from the gui :slight_smile:
I’m not requesting the removal of Rules DSL. I just want to see it become an add-on instead of part of core. But it’s just a wish. Not a prediction or something that will happen without a volunteer to do the work.
They are all good. JS and jRuby probably have the most people on the forum if you run into trouble and need help. But your existing Rules DSL will continue to work too. If I get my wish the only thing that would change is you’d have to install an add-on first.
I also do not recommend rewriting what you have. But I do recommend for new development considering the other options.
Nothing in this world is “permanent”. But I don’t see any of the currently offered options going away. And there’s a new kid on the block undergoing testing with the GraalVM Python add-on on the marketplace which will add Python 3 support. Except for JRule and HABApp, all the rules add-ons options are a part of the main OH project so even if a maintainer quits we have the ability to pick up the project and continue supporting it. Any one of them is a safe option. But again, Rules DSL isn’t going anywhere either. It’s just the worst choice among the available options now instead of the best one. in terms of completeness, ease of use, and features.
Copilot might find it a little easier to deal with a well known language as opposed to a niche custom language. Given the right prompt that is.
Assuming you stuck with Rules DSL an example of what @hmerk suggests…
rule "Battery status"
    Member of Batteries changed
    if(triggeringItem.state instanceof Number && (triggeringItem.state as Number) < 10) {
        sendNotification("xxx@gmx.de", "🔋 Die Batterie im Bewegungsmelder vorm Esszimmer ist leer (Eine CR2450-Batterie).", "battery", "Battery Tag", "Da Hoam", "Treppenhaus-bat-id-2", null, null, null, null, null) // I don't speak German but use triggeringItem.label to get a nice friendly name for the Item to use in your notifications.
   else if(newState == ON) {
    sendNotification("xxx@gmx.de", "🔋 Die Batterie im Thermometer im KiZi 2 ist leer (Zwei AAA-Batterien).", "battery", "Battery Tag", "Da Hoam", "KiZi_2-bat-id-5", null, null, null, null, null) // again, use triggeringItem.label to create your notification message
That one rule will handle all of your battery Items.
In JS using rule builder this could look like the following:
rules.when().memberOf("Batteries").changed()
     .then(event => {
       if(items[event.itemName].numericState !== null) {
           actions.notificationBuilder("🔋 Die Batterie "+ items[event.itemName] + " ist leer (Zwei AAA-Batterien).")
                  .addUserId('xxx@icloud.com, xxx@gmx.de')
                  .withTitle('Da Hoam')
                  .send(); // see https://www.openhab.org/addons/automation/jsscripting/#cloud-notification-actions for details on how to use notificationBuilder
       else if(items[event.itemName].state == "ON") {
    .build("Battery Low Notification", "Sends a notification to the icloud and gmx emails when a battery gets below 10 or ON", ["batteries"], "batteryAlert");
Notice how we can send the message to both emails with just the one call using notificationBuilder.
Notice how we can set the description, tags, and UID for the rule, not just the rule name (second, third and forth arguments to build().
You could also use tags and/or metadata on the Item for information needed to construct the message on a per-battery basis. For example you can have metadata on the Items that indicate what sort of battery they take to include in the alerting message.
Of the above, only Item tags are supported by Rules DSL.
I have the older versions as well and I wrote this python code to glue it to mqtt. GitHub - mjcumming/Somecomfort-Homie: Homie v3 for Honeywell Thermostats
The code looks fairly straight forward. Do you think it would be difficult to create a binding with this as an example? Since I have it working using IFTTT, I don’t necessarily need this right now but if I could pull it into OH, that would be ideal.
Great to hear I don‘t have to rework all my rules. Of course I will try to rework them from time to time.
And for new ones I‘ll investigate into those other options.
Thx for your examples.
However, for now, I have a specific request for openHAB 5: Please make the main UI configurable via text-based files that can be edited using tools like VS Code, instead of solely relying on the web UI as it is currently.
In case you are talking about configuring things, items, rules, … via text-based files, you can use the DSL syntax and edit your files with VS Code. It is there since the first version of openHAB.
No I really meant changing the main ui Pages via textbased files.
For me it makes the whole thing easier, if I exchange an item, for example, for different reasons, so that at the time of the basic ui I could simply use the vs code search function and knew at a glance where I used the item in the gui. Now I have to look up severall layout pages in the web ui.
But only a modest wish from an enthusiastic user :wink:
Or is there an easier way?
You also casually said that you can only edit rules according to the dsl syntax text-based - is this true? According to my understanding, you can use almost any form of syntax for rules based on text, except blocky, right?
You could search in the corresponding jsondb file in which page that item appears from command line. If you are enthusiastic, you could also make a nice widget around that cli command.
Yes
Sorry still didn‘t get it - yes to only dls syntax or yes to rules can have any syntax in filebased config?
Ok I will try it but still hopping somebody investigates if it is possible to make Main ui textfile based.
There is also the developer sidebar which will let you search. It searches inside everything including UI widgets.
No, you can create script actions, script conditions, and transformations in the UI using Rules DSL.
Yes, as of now that’s the case.
THX - now I got it.
And sorry for getting so off topic!
I think we should spent more focus on improving the UI capabilities if we want to be able to compete with other Open Source and Closed Source products. I still see many components with limited and/or inconsistent visual design or user interaction options - at the same time it is quite hard to either fix/change these issues (e.g. through CSS fixes) or build new custom components without the restrictions OH puts onto plain F7 components.
I had described more details in this post when I tried OH3:
https://community.openhab.org/t/oh3-ui-some-great-some-not-so-great-design-decisions-and-prioritizations/115165
Some details may have changed since then, but the more fundamental issues persist I believe.
I disagree. We need not improve UI variability to convince more people or to ‘compete’ with whoever. Why should we be investing time right there?
What you’re asking for is even more control and even more complexity. If you have a specific idea of what you want to have your personal UI outcome look like and don’t manage to create it in OH that can be annoying. However, does that mean we really need more variability? Does that apply to a relevant number of users?
Note it’s not about small concrete requests for improvement. Post them here on the forum or open single feature requests for those on GitHub and if sound and pragmatically doable I’m sure you will be heard.
But variability improvement as a fundamental of your wish list is where I disagree as-fundamentally. Variability is boon and bane, it comes at great cost, and we must not be wasting our resources. And we’re very flexible already, particularly when you compare OH capabilities to other HA systems.
What we really need isn’t even more customizable widgets but rather the opposite:
more easy-to-deploy, predefined widgets and applications to select from. Of which there now are some. The marketplace has grown quite some in those 4 yrs since your last post, check it out.
Regarding docs and examples, sure there’s never enough of them or not written to match your expectations.
But they have improved A LOT since your other post, which was right after Main UI release.
You really should be checking back with the current official docs and rewrite your post rather than to simply restate it.
Hi c_r,
absolutely correct.
There has been a small discussion on this topic and it has been agreed to collect ideas and to support these ideas with detailed information in a separate github ticket.
Please see here:
and here:
https://github.com/openhab/openhab-webui/issues/3037
There are more tickets to come. Each of them focussing on separate GUI components.
