Hey guys,
i am struggling with the integration of a InterTechno dimmer. I wanted to use the exec binding like I did in Openhab 1. Unfortunately the binding changed. So for the normal switches I now use a rule which sends 1 or 0 to a Number Item which is combined with the Exec thing. The thing fires if the Number changes. For the dimmer unfortunately I need the 1 for starting the dimming process as well as for stopping it. 0 is for light off. So if I start dimming with 1, the Number Item is set to 1 and the thing fires the command. But now, if I want to stop the dimming process and the Number Item is still 1 there is no Item Change and the thing doesn’t fire the command.
Maybe you have a kind solution for this, cause I haven’t.
Best Regards to all of you.
