Identify itemname based on part of a name
See my Assocaited Items Design Pattern.
Assuming that all your Items are a member of a Group then:
gTex_Zone.filter[sw|sw.name.contains("some string")
First, I might recommend coming up with a more meaningful naming pattern. Numbers make a lot of sense to computers but before long you will be scratching your head wondering “What light was Tex_Zone_Z025_102 again?” It is just as easy for OH and your Rules to deal with human meaningful names and then your code becomes more self-documenting.
There are lots of approaches to naming patterns and several threads on this forum on the topic. My latest approach is:
If the name starts with:
  • g - Group
  • v - sensor value or state
  • a - actuator
  • t - Expire based timer
The first word is the general functionality the Item addresses (e.g. Network, Lighting, etc). I’m not always diligent about this part and have a lot of legacy Items from before I adopted this convention.
I separate the parts of the name by _.
The last parts of the name can be anything depending on context.
So, for example, I have some code that generates an alert when certain remote sensors stop reporting. The relevant Items for one of those devices (named manticore in my DNS):
Group gManticore_SensorReporter (gSensorGroups)
Switch vNetwork_Manticore "Manticore Network [MAP(admin.map):%s]"
  <switch>
  { channel="network:device:manticore:online", expire="1m" }
Switch vManticore_SensorReporter_Online "Manticore sensorReporter [MAP(admin.map):%s]"
    <network> (gSensorStatus)
    { mqtt="<[chimera:status/sensor-reporters:command:OFF:.*manticore sensorReporter is dead.*]", expire="10m,command=OFF" }
String vManticore_SensorReporter_Uptime "Manticore sensorReporter Uptime [%s]"
    <clock> (gManticore_SensorReporter)
    { mqtt="<[chimera:status/manticore/heartbeat/string:state:default]" }
And then in my rules I can do things like:
// Given vManticore_SensorReporter_Uptime which receives a heartbeat I can:
// Get the parts of the name
var uptimeSplit = uptime.name.split("_")
// Get the Group:
var groupName = uptimeSplit.get(0).replace('v','g') + "_" + uptimeSplit.get(1)
gSensorGroups.members.filter[gr|gr.name == groupName
// Get the associated Online Item
var online = uptimeSplit.get(0) + "_" + uptimeSplit.get(1) + "_Online"
As long as the naming is consistent and easy to split apart and they are put into Groups it is relatively easy to pull associated items.
