I’m getting really strange behavior with IFTTT lately.
I set up a bunch of rules using IFTTT and its integration with MyOpenhab. They all continue to work fine, and IFTTT can send commands to items using the rules I set up.
However, if I go to edit an existing rule or create a new rule, the drop-down on IFTTT to select which item to send a command to just shows “Options Unavailable.” Rules that already exist continue to run fine, so obviously OpenHab is communicating with IFTTT.
Is there any way to fix this?
