I get this error msg, what can be wrong?
2017-02-19 00:21:33.979 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'default.items’
2017-02-19 00:21:33.982 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘ihc’ of item ‘Belysning_Framsida’ could not be parsed correctly.
java.lang.NumberFormatException: For input string: "_0x9fb5b"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)[:1.8.0_121]
at java.lang.Integer.parseInt(Integer.java:580)[:1.8.0_121]
at java.lang.Integer.parseInt(Integer.java:615)[:1.8.0_121]
at org.openhab.binding.ihc.internal.IhcGenericBindingProvider.getResourceIdFromString(IhcGenericBindingProvider.java:193)[181:org.openhab.binding.ihc:1.9.0]
at org.openhab.binding.ihc.internal.IhcGenericBindingProvider.processBindingConfiguration(IhcGenericBindingProvider.java:166)[181:org.openhab.binding.ihc:1.9.0]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:48)[182:org.openhab.core.compat1x:2.0.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:284)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:167)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:347)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
