Setup:
Zigbee coordinator: SiLabs Ember based NCP (BitronVideo)
ZigBee device: IKEA BADRING water sensor
Issue:
I’m having problem with BADRING water sensor. The pairing is not completed (status UNINITIALIZED), either no channels, or channels are (partially?) created, and in the log I can see exception:
2024-12-21 22:06:42.182 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - null: Exception creating channels
java.lang.NullPointerException: Cannot invoke "Object.hashCode()" because "key" is null at java.util.concurrent.ConcurrentHashMap.get(ConcurrentHashMap.java:936) ~[?:?] at com.zsmartsystems.zigbee.ZigBeeNetworkManager.getNode(ZigBeeNetworkManager.java:1647) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.getNode(ZigBeeCoordinatorHandler.java:1003) ~[bundleFile:?] at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.createZigBeeChannelConverter(ZigBeeThingHandler.java:551) ~[bundleFile:?] at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.initializeDevice(ZigBeeThingHandler.java:532) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:394) [bundleFile:?] at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:244) [bundleFile:?] at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:1) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?] at java.lang.Thread.run(Thread.java:840) [?:?]
Interestingly other IKEA bulbs or PARASOLL window sensor works.
What are the next steps so someone can help? Or is anyone this one working?
