Hi, I don’t know if this is the proper topic, but this is related to these binding.
I just paired Ikea brand new e1810 to z2m network, but it is not running as intended a day after pairing.
Now I just replaced the battery, re-pair it to z2m and it is connected to coordinator (sonoff USB coordinator). While the remote is now working, every time I press the toggle (center) button, it toggles my xiaomi plug nearby.
The last interview with z2m is when I put it 5cm apart with coordinator. On The previous (5 minutes earlier) interview the plug is between the coordinator and the remote.
I didn’t add this Ikea thing so it should not trigger anything, and my rebuilt OH 4.3.1 is new, only have 2 rules to respond 2 buttons of this Ikea remote.
However, I have rules on old OH 3.2.0 to turn on the plug if it turned off.
Do you have similar experience? How do you fix this issue?
Here I attached the z2m map with only affected devices.
z2m log:
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom', payload '{"action":"","battery":16,"linkquality":60,"update":{"installed_version":587286065,"latest_version":604241925,"state":"available"},"update_available":true}'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/battery', payload '16'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/update-state', payload 'available'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/update-installed_version', payload '587286065'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/update-latest_version', payload '604241925'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/update_available', payload 'true'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/linkquality', payload '60'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/action', payload ''
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Ikea TRADFRI remote Masterbedroom/action', payload 'toggle'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1', payload '{"consumption":6277.4716796875,"device_temperature":39,"energy":6277.47,"linkquality":90,"power":845.45,"power_outage_count":154,"power_outage_memory":null,"state":"OFF","temperature":44,"update":{"installed_version":90,"latest_version":92,"state":"available"},"update_available":true}'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/state', payload 'OFF'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power', payload '845.45'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/consumption', payload '6277.4716796875'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/energy', payload '6277.47'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/temperature', payload '44'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power_outage_count', payload '154'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/linkquality', payload '90'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/device_temperature', payload '39'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-state', payload 'available'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-installed_version', payload '90'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-latest_version', payload '92'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update_available', payload 'true'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power_outage_memory', payload ''
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1', payload '{"consumption":6277.4716796875,"device_temperature":39,"energy":6277.47,"linkquality":90,"power":0,"power_outage_count":154,"power_outage_memory":null,"state":"OFF","temperature":44,"update":{"installed_version":90,"latest_version":92,"state":"available"},"update_available":true}'
info 2025-01-07 21:58:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power', payload '0'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1', payload '{"consumption":6277.4716796875,"device_temperature":39,"energy":6277.47,"linkquality":84,"power":0,"power_outage_count":154,"power_outage_memory":null,"state":"ON","temperature":44,"update":{"installed_version":90,"latest_version":92,"state":"available"},"update_available":true}'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/state', payload 'ON'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power', payload '0'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/consumption', payload '6277.4716796875'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/energy', payload '6277.47'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/temperature', payload '44'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power_outage_count', payload '154'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/linkquality', payload '84'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/device_temperature', payload '39'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-state', payload 'available'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-installed_version', payload '90'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update-latest_version', payload '92'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/update_available', payload 'true'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/power_outage_memory', payload ''
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1', payload '{"consumption":6277.4716796875,"device_temperature":39,"energy":6277.47,"linkquality":81,"power":0,"power_outage_count":154,"power_outage_memory":null,"state":"ON","temperature":44,"update":{"installed_version":90,"latest_version":92,"state":"available"},"update_available":true}'
info 2025-01-07 21:58:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/plug_ac_room1/linkquality', payload '81'
