IKEA PARASOLL and VALLHORN sensors
IKEA’s new PARASOLL and VALLHORN Zigbee sensors are now available in North America. I’ve been waiting for these for months, and grabbed them as soon as possible to replace a variety of flaky Z-Wave sensors and my flakier Sonoff SNZB-04 contact sensors.
Both sensors paired immediately with Zigbee2MQTT, giving me no trouble at all. I can’t speak to the reliability yet since it’s only been a few days, but I’m particularly pleased with the PARASOLLs.
PARASOLL
The design of the PARASOLL is really smart, because there’s a ton of flexibility for mounting them. Both parts are long and slim, but the sensor is thick while the magnet is skinny. Plus, the sensor can be triggered from the front or either side at a distance of about 2-3cm. As a result, you shouldn’t need a riser to make sure that the sensor and magnet can find each other.
I couldn’t mount the Sonoff sensors on my bedroom casement windows, because they were too bulky to fit between the window frame and the screen. Not so with the PARASOLLs! The skinny magnets are mounted on the frame, and the sensor is on the window (which opens outward).
Both parts come with strong mounting tape attached, and you can also use screws for the sensor bases. The sensors unclip from their bases to reveal the pairing button and sealed battery compartment (a nice touch for sensors that might get wet when it rains). The clips are my only complaint…it’s a little harder to detach the sensors than it should be.
VALLHORN
The VALLHORN isn’t as lovable as the PARASOLL. It’s big, kind of ugly, and can only be mounted flat on a wall or in a corner. You can’t angle it up or down, so you’ll need to get creative if you want to point it in a specific direction. However, the detection angle is fairly wide and they’re quick to respond, so that might not be necessary.
Same as the PARASOLL, the VALLHORN sensor clips into a base that can be mounted with tape or screws. And same as the PARASOLL, it’s a little harder to unclip the sensor than it should be. The battery door is also sealed, which is good for use in a bathroom.
Some users have reported a lot of false positives, but I’ve been using two VALLHORNs for about a week without any problems. The Internet seems to think that they work better with the recommended IKEA LADDA rechargeable batteries, which are 1.2V (as opposed to 1.5V alkalines). I can’t say whether this is true or not, but it’s fine by me since LADDAs are excellent batteries for how little they cost.
In addition to motion, the VALLHORN reports illumination in lux. Both of my sensors reported the same values, which is a good start. They can be calibrated with Zigbee2MQTT if necessary.
Got mine today. As for the Parasoll, it pairs perfectly via the Zigbee-Binding. The only trick (not really mentioned in the manual) is to get it into pairing mode (pressing the pairing-button four times).
Hah, I also had to search for the pairing process.
Good to know that it works natively in the Zigbee binding! I recall reading that TRADFRI stuff was hit-or-miss, so maybe IKEA is staying more within the Zigbee 3.0 specs now.
I’m super happy with both sensors.
Not sure if they changed something recently with the
firmware, but my three Tradfri drivers worked with the Zigbee Binding out of the box without any problems.
How about the VALLHORN motion sensor?
I am trying to set it up via zigbee2mqtt. Problem is that the latency. What channels are you using for trigger a rule?
Do you got some example textual configs?
cheers!
I can’t say whether it works or not with the Zigbee Binding, but you can always try it. I would guess that it would be okay. Perhaps @Cplant can confirm.
I haven’t noticed any more latency with VALLHORNs than with any other sensors/devices I have in Zigbee2mqtt. Keep in mind that PIR motion sensors are rarely immediate, because they have to register enough movement to trigger a change.
The only channel that’s useful for motion detection is Occupancy.
No. I don’t use textual configs for things.
I would think so too, since all others work. Though haven’t tried the Vallhorn myself (another good reason to go to IKEA and get one). :wink:
If I stop the Z2M service and then install the Zigbee binding, would the devices I’ve already paired in Z2M automatically show up in my inbox? Or would I need to pair them again via the Zigbee Binding?
I’ve never tried switching, so I have no idea what happens when you go from one to the other. If it’s easy, I can test the Vallhorn and then go back to Z2M.
Probably a question that an architect behind Z2M or the binding can answer, but it boils down to the question on where the paring information are being saved. If those infos (incl. encryption details) are not being stored on the stick itself (which sounds plausible to me) then it could work.
The information about devices is not stored on the dongle. Each software performs an interview to determine the features that a device supports.
If you run different software, the new software will need to do this again. For battery devices, this is a problem since they mostly sleep. For mains powered devices it’s likely that they will be fully rediscovered relatively quickly (it may take an hour or two - depending on the device and
Reporting configuration).
Chris
