Cplant
(Cplant)
February 10, 2024, 3:28pm
1
I’m on OH 4.1, using a Sonoff Zigbee dongle with the openHAB Zigbee-Binding.
If I pair the Styrbar button with openHAB, it works great for two of the four buttons (the ones for on/off). The other two buttons, however, (the ones that control the light temperature) do not appear under Channels:
Is there a way to access the events of the other two buttons as well via the Zigbee-Binding? I assume that with Z2M it will be possible.
rpwong
(Russ)
February 13, 2024, 7:06pm
2
I’m guessing that the missing events don’t follow the Zigbee standard. I recall reading that IKEA devices are a mixed bag in that regard.
I use Z2M, so I don’t know how you would go about getting the events added (or if that’s possible). You can try using the console to dig out more information.
Here’s what you get in Z2M.
Cplant
(Cplant)
February 13, 2024, 8:21pm
3
Looking at the documentation there appear to be quite a few commands that have the potential to mess things up if you don’t know what you’re doing exactly. Which is the command that I should use safely? Is there maybe the equivalent to log:tail?
rpwong
(Russ)
February 13, 2024, 8:26pm
4
I assume you would start with what’s recommended in the documentation: fingerprint. I’ve no idea beyond that, since I use Z2M.
Cplant
(Cplant)
February 19, 2024, 9:17pm
5
Thanks.
Just in case someone reads this and is a bit more into the binding: This is what zigbee node XXXXX comes up with:
|>| Node Descriptor
| |> Logical Type END_DEVICE
| |> MAC Capabilities [REDUCED_FUNCTION_DEVICE]
| |> Stack Compliance 22
| |> Server Capabilities []
| |> Buffer Size 82
| |> Incoming Transfer Size 82
| |> Outgoing Transfer Size 82
|>| Power Descriptor
| |> Available Power Sources [MAINS]
| |> Current Power Source MAINS
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest TIMEOUT
| |> IeeeAddressRequest SUCCESS
| |> ManagementLqiRequest SUCCESS
| |> ManagementRoutingRequest NOT_SUPPORTED
|>| Basic Information
| |> Generic Device Class 0
| |> Generic Device Type 226
| |> Manufacturer Name IKEA of Sweden
| |> Model Indentifier RODRET Dimmer
| |> Product Code ByteArray [value=45 32 32 30 31]
| |> Product URL
| |> Date Code 20221114
| |> Application Version 1
| |> Software Build ID 1.0.47
| |> Hardware Version 1
| |> Zcl Version 8
| |> Stack Version 113
| |>| Endpoint 1
| | |> Profile 0104 ZIGBEE_HOME_AUTOMATION
| | |> Device Type 0820 NON_COLOR_CONTROLLER
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | |>| Commands Received
| | | | | |> 0000 ResetToFactoryDefaultsCommand
| | | | |>| Attributes Supported
| | | | | |> 0000 ZCL Version >> UNSIGNED_8_BIT_INTEGER 8
| | | | | |> 0001 Application Version >> UNSIGNED_8_BIT_INTEGER 1
| | | | | |> 0002 Stack Version >> UNSIGNED_8_BIT_INTEGER 113
| | | | | |> 0003 HW Version >> UNSIGNED_8_BIT_INTEGER 1
| | | | | |> 0004 Manufacturer Name >> CHARACTER_STRING IKEA of Sweden
| | | | | |> 0005 Model Identifier >> CHARACTER_STRING RODRET Dimmer
| | | | | |> 0006 Date Code >> CHARACTER_STRING 20221114
| | | | | |> 0007 Power Source >> ENUMERATION_8_BIT 3
| | | | | |> 0008 Generic Device Class >> ENUMERATION_8_BIT 0
| | | | | |> 0009 Generic Device Type >> ENUMERATION_8_BIT 226
| | | | | |> 000A Product Code >> CHARACTER_STRING ByteArray [value=45 32 32 30 31]
| | | | | |> 000B Product URL >> CHARACTER_STRING
| | | | | |> 4000 SW Build ID >> CHARACTER_STRING 1.0.47
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 3
| | | |>| Cluster 0001 Power Configuration
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0003 Identify
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0020 Poll Control
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 1000
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster FC7C
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | | |> Type Client [Output]
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Unsupported locally
| | | |>| Cluster 0006 On/Off
| | | | |>| Commands Generated
| | | | | |> 0000 OffCommand
| | | | | |> 0001 OnCommand
| | | | | |> 0002 ToggleCommand
| | | | |>| Commands Received
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 2
| | | |>| Cluster 0008 Level Control
| | | | |>| Commands Generated
| | | | | |> 0000 MoveToLevelCommand
| | | | | |> 0001 MoveCommand
| | | | | |> 0002 StepCommand
| | | | | |> 0003 StopCommand
| | | | | |> 0004 MoveToLevelWithOnOffCommand
| | | | | |> 0005 MoveWithOnOffCommand
| | | | | |> 0006 StepWithOnOffCommand
| | | | | |> 0007 StopWithOnOffCommand
| | | | |>| Commands Received
| | | |>| Cluster 0019 Ota Upgrade
| | | | |>| Commands Generated
| | | | | |> 0001 QueryNextImageCommand
| | | | | |> 0003 ImageBlockCommand
| | | | | |> 0006 UpgradeEndCommand
| | | | |>| Commands Received
| | | | | |> 0000 Upgrade Server ID >> IEEE_ADDRESS E0798DFFFEA7C935
| | | | | |> 0001 File Offset >> UNSIGNED_32_BIT_INTEGER -1
| | | | | |> 0002 Current File Version >> UNSIGNED_32_BIT_INTEGER 16777287
| | | | | |> 0006 Image Upgrade Status >> ENUMERATION_8_BIT 0
| | | | | |> 0007 Manufacturer ID >> UNSIGNED_16_BIT_INTEGER 4476
| | | | | |> 0008 Image Type ID >> UNSIGNED_16_BIT_INTEGER 65535
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 4
| | | |>| Cluster 1000
| | | | |> Unsupported locally
Maybe there’s something I can do on my end. If the Binding needs adjustment, I’m more than happy to test.
system
(system)
Closed
April 1, 2024, 1:17pm
6
