@Jens_Schanz how can i use dynamic variables instead of static ones, ie, how can i replace the rules execute command (executeCommandLine("/etc/openhab2/scripts/hue_tradfri_color.sh 6 Schl_Bambus_bu_brightness " + Schl_Bambus_bu_colorpicker.state)) in the script for the number of the specific bulb, and the color that i picked in ColorPicker?
as I know the script isn’t necessary anymore.
In OpenHAB >2.5 everything works out of the box.
If you want to use the script, please have a look at IKEA Tradfri Color Changing bulb on Hue Bridge no control of colors - #54 by DomDom16
@DomDom16 maybee has the solution for your problem.
Rgrds
Jens
Yep. That is the script i’ve been using. It works perfecty form the command line. I would like to know please, how to pass the values form color picket into the comand line.
I don’t know much about the internals of openhab to know how to obtain a variable within a colorpicker and then to pass it to the script.
Can you help me please?
But with 1.3.002 is still not working?
While Ikea bulbs don’t have this issue anymore with newer firmware, this issue still is the case for Müller tint and LivarnoLux (Lidl) bulbs.
I can change the colors in the Hue and Hue Essentials app. I can not change them in OpenHAB.
Well, that’s not entirely true.
If I select a color in the app, then OpenHAB can change the colors, but I can not select warm white tones.
If I select a warm-white tone in the app, then OpenHAB can change the warm-white tone, but can not select colors.
This is the case for both above brands of bulbs, connected to a Philips Hue hub, using OpenHAB 2.5.12
/M
