Ikea Tradfri LED1837R5 gu10 dimming bulbs (3off) via zigbee2mqtt
We have three Ikea Tradfri gu10 400lm dimmable bulbs, located in the upstairs hallway.
Here is how I integrated into openHAB, via zigbee2mqtt and Mosquitto .
Prerequisites
  • Ensure the openHAB MQTT binding is installed (V2, not V1)
  • My Mosquitto MQTT broker is setup as per the initial installation defaults.
  • Pair the device with zigbee2mqtt as described here .
    • Ensure that you are able to pair devices by setting permit_join to true in configuration.yaml (usually in /opt/zigbee2mqtt/data)
  • Once paired, adjust the zigbee2mqtt configuration.yaml (usually in /opt/zigbee2mqtt/data) to:
Here is my configuration.yaml - your device ID is likely to be different. I have given my device the friendly names according to what they are closest to:
  • bUpstairsHallwayBathroomLight
  • bUpstairsHallwayMiddleLight
  • bUpstairsHallwayCupboardLight
homeassistant: false
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://localhost'
serial:
  port: /dev/ttyACM0
  disable_led: false
advanced:
  log_level: error
  availability_timeout: 5
devices:
  '0x680ae2fffe7f1dfb':
    friendly_name: bUpstairsHallwayBathroomLight
  '0x680ae2fffe93efaf':
    friendly_name: bUpstairsHallwayMiddleLight
  '0x588e81fffe15418b':
    friendly_name: bUpstairsHallwayCupboardLight
experimental:
  output: attribute
openHAB
MQTT bridge
I have a separate file which just contains the bridge Thing to my Mosquitto MQTT broker:
Bridge mqtt:broker:MosquittoMqttBroker "Mosquitto MQTT Broker" [
	host="192.168.1.92",
	secure=false,
	port=1883,
	clientID="OpenHAB2"
zigbee.things
//HALLWAY LIGHTS
//Bathroom
Thing mqtt:topic:bUpstairsHallwayBathroomLight "Upstairs Hallway Bathroom" (mqtt:broker:MosquittoMqttBroker) {
	Channels:
	    Type switch:switch "Power Switch" [
			stateTopic="zigbee2mqtt/bUpstairsHallwayBathroomLight/state",
			commandTopic="zigbee2mqtt/bUpstairsHallwayBathroomLight/set",
			on="ON",
			off="OFF"
	    Type dimmer:dimmer "Dimmer" [
			stateTopic="zigbee2mqtt/bUpstairsHallwayBathroomLight/brightness",
			commandTopic="zigbee2mqtt/bUpstairsHallwayBathroomLight/set/brightness",
			min=0,
			max=255,
			step=1
	    Type switch:reachable "Reachable" [
			stateTopic="zigbee2mqtt/bUpstairsHallwayBathroomLight/availability",
			on="online",
			off="offline"
//Middle
Thing mqtt:topic:bUpstairsHallwayMiddleLight "Upstairs Hallway Middle" (mqtt:broker:MosquittoMqttBroker) {
	Channels:
			stateTopic="zigbee2mqtt/bUpstairsHallwayMiddleLight/state",
			commandTopic="zigbee2mqtt/bUpstairsHallwayMiddleLight/set",
			on="ON",
			off="OFF"
			stateTopic="zigbee2mqtt/bUpstairsHallwayMiddleLight/brightness",
			commandTopic="zigbee2mqtt/bUpstairsHallwayMiddleLight/set/brightness",
			min=0,
			max=255,
			step=1
			stateTopic="zigbee2mqtt/bUpstairsHallwayMiddleLight/availability",
			on="online",
			off="offline"
//Cupboard
Thing mqtt:topic:bUpstairsHallwayCupboardLight "Upstairs Hallway Middle" (mqtt:broker:MosquittoMqttBroker) {
	Channels:
			stateTopic="zigbee2mqtt/bUpstairsHallwayCupboardLight/state",
			commandTopic="zigbee2mqtt/bUpstairsHallwayCupboardLight/set",
			on="ON",
			off="OFF"
			stateTopic="zigbee2mqtt/bUpstairsHallwayCupboardLight/brightness",
			commandTopic="zigbee2mqtt/bUpstairsHallwayCupboardLight/set/brightness",
			min=0,
			max=255,
			step=1
			stateTopic="zigbee2mqtt/bUpstairsHallwayCupboardLight/availability",
			on="online",
			off="offline"
zigbee.items
  • All the power switch Items are part the gHallwayLights switch Group, which is setup so that if any of the bulbs are ON, the Group itself is ON.
  • All the dimmer Items are part of the gdHallwayLights dimmer Group, which is setup so that the Group takes the maximum dimmer setting of any bulb.
  • See here for more ways to setup your groups.
Group:Switch:OR(ON,OFF) gHallwayLights
Group:Dimmer:MAX gdHallwayLights
//HALLWAY LIGHTS
//Hallway bathroom
Switch sUpstairsHallwayBathroomLight "Porch Light" (gHallwayLights) { channel="mqtt:topic:bUpstairsHallwayBathroomLight:switch" }
Dimmer dUpstairsHallwayBathroomLight "Porch Light" (gdHallwayLights) {channel="mqtt:topic:bUpstairsHallwayBathroomLight:dimmer"}
Switch sUpstairsHallwayBathroomLightReachable "Porch Light" { channel="mqtt:topic:bUpstairsHallwayBathroomLight:reachable" }
//Hallway middle
Switch sUpstairsHallwayMiddleLight "Porch Light" (gHallwayLights) { channel="mqtt:topic:bUpstairsHallwayMiddleLight:switch" }
Dimmer dUpstairsHallwayMiddleLight "Porch Light" (gdHallwayLights) {channel="mqtt:topic:bUpstairsHallwayMiddleLight:dimmer"}
Switch sUpstairsHallwayMiddleLightReachable "Porch Light" { channel="mqtt:topic:bUpstairsHallwayMiddleLight:reachable" }
//Hallway cupboard
Switch sUpstairsHallwayCupboardLight "Porch Light" (gHallwayLights) { channel="mqtt:topic:bUpstairsHallwayCupboardLight:switch" }
Dimmer dUpstairsHallwayCupboardLight "Porch Light" (gdHallwayLights) {channel="mqtt:topic:bUpstairsHallwayCupboardLight:dimmer"}
Switch sUpstairsHallwayCupboardLightReachable "Porch Light" { channel="mqtt:topic:bUpstairsHallwayCupboardLight:reachable" }
sitemap
In the screenshot below:
  • You can see that the Bathroom and Middle bulbs are on, so the Group switch (under All) is on too.
  • The Middle bulbs’ brightness is the largest at 50%, so the Group dimmer (under All) is 50%.
  • If you now click the Group switch (under All), all bulbs would switch OFF. If you clicked it again, all bulbs would switch ON to their last individual brightness setting.
  • If one of the bulbs becomes unavailable (lost power, for example), its controls would disappear, to be replaced by an error icon.
Frame label="All"{
	Switch item=gHallwayLights label="Switch" icon="light"
	Slider item=gdHallwayLights label="Dimmer [%d %%]" sendFrequency=500
Frame label="Bathroom"{
	Switch item=sUpstairsHallwayBathroomLight label="Switch" icon="light" visibility=[sUpstairsHallwayBathroomLightReachable==ON]
	Slider item=dUpstairsHallwayBathroomLight label="Dimmer [%d %%]" sendFrequency=500 visibility=[sUpstairsHallwayBathroomLightReachable==ON]
	Text item=sUpstairsHallwayBathroomLightReachable label="Bathroom light [MAP(switch2online.map):%s]" icon="error" visibility=[sUpstairsHallwayBathroomLightReachable==OFF]
Frame label="Middle"{
	Switch item=sUpstairsHallwayMiddleLight label="Switch" icon="light" visibility=[sUpstairsHallwayMiddleLightReachable==ON]
	Slider item=dUpstairsHallwayMiddleLight label="Dimmer [%d %%]" sendFrequency=500 visibility=[sUpstairsHallwayMiddleLightReachable==ON]
	Text item=sUpstairsHallwayMiddleLightReachable label="Middle light [MAP(switch2online.map):%s]" icon="error" visibility=[sUpstairsHallwayMiddleLightReachable==OFF]
Frame label="Cupboard"{
	Switch item=sUpstairsHallwayCupboardLight label="Switch" icon="light" visibility=[sUpstairsHallwayCupboardLightReachable==ON]
	Slider item=dUpstairsHallwayCupboardLight label="Dimmer [%d %%]" sendFrequency=500 visibility=[sUpstairsHallwayCupboardLightReachable==ON]
	Text item=sUpstairsHallwayCupboardLightReachable label="Cupboard light [MAP(switch2online.map):%s]" icon="error" visibility=[sUpstairsHallwayCupboardLightReachable==OFF]
The switch2online.map file contains the below, saved into the transform folder:
OFF=OFFLINE
ON=ONLINE
NULL=UNDEFINED
Hello! I checked the work of experimental:
output: attribute. Unfortunately, it didn’t work out. Still have to go to the settings of the Paper UI channel in the Transform Values option
Incoming Value Transformations specify:
JSONPATH:$. state
Only with this setting in the Paper UI, the feedback of the sonoff zb mini relay status in the openhab software interface works correctly. What do you think, why did I fail? Maybe it’s because of the Paper UI ? Did you need to create Things, Items in text form?
Figured it out!!!))) Everything works fine if you correctly specify the path to the state topic. In the case of using experimental:
output: attribute it is not enough to specify the path: zigbee2mqtt/zb mini sonoff, when the channel settings were JSONPATH:$. stete, when using the experimental option, the path in the Parer UI should be: Others
MQTT State Topic
zigbee2mqtt/zb mini sonoff/state In this case, state is required!!!
