I'm trying to get Habmin installed
openhab.log
…2024-12-03 14:54:26.513 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.2.3 (Release Build)
2024-12-03 14:54:26.921 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘America/Los_Angeles’.
2024-12-03 14:54:26.929 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘38.56773023927109,-121.30240917205812’.
2024-12-03 14:54:26.931 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘en_US’.
2024-12-03 14:54:41.879 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2024-12-03 14:54:57.318 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-12-03 14:55:03.810 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2024-12-03 14:55:03.811 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2024-12-03 14:55:06.997 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration ‘Configuration[{key=controller_softreset; type=Boolean; value=false}, {key=security_networkkey; type=String; value=66 E1 72 25 AD CF 95 A7 99 56 E3 27 7C 35 B5 14}, {key=security_inclusionmode; type=BigDecimal; value=1}, {key=controller_sisnode; type=BigDecimal; value=0}, {key=controller_maxawakeperiod; type=BigDecimal; value=10}, {key=controller_sync; type=Boolean; value=false}, {key=controller_master; type=Boolean; value=true}, {key=inclusion_mode; type=BigDecimal; value=2}, {key=port; type=String; value=/dev/ttyACM0}, {key=controller_wakeupperiod; type=BigDecimal; value=3600}, {key=controller_exclude; type=Boolean; value=false}, {key=heal_time; type=BigDecimal; value=2}, {key=controller_inclusiontimeout; type=BigDecimal; value=30}, {key=controller_hardreset; type=Boolean; value=false}]’ on thing ‘zwave:serial_zstick:Z-WaveController’ blocked. This is most likely a bug: {controller_sisnode=The value must not be less than 1.}
2024-12-03 15:15:20.377 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn’t exist:
2024-12-03 15:16:49.216 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn’t exist:
2024-12-03 15:53:01.902 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.io.habmin [274]
Unresolved requirement: Import-Package: com.sun.jersey.api.json
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.7.4]
2024-12-03 15:53:01.910 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.7.4]
2024-12-03 15:53:01.912 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.binding.zwave-1.8.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [273]
Unresolved requirement: Import-Package: org.apache.commons.lang
2024-12-03 16:22:33.556 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI…
Events.log
I removed the zwave .jar file from addons since it’s not needed.
I also highlighted my original post for clarification.
I think I may have gotten initialization and inclusion confused. I think I’m looking for a proper way to include the switch.
