I’m testing my Russound binding and have encountered an ?issue? with the Image. Russound provides a cover art URL for the song currently playing. I had hoped to simply do “Image item=[myitem]” (where the item is a string type containing the url) and have the cover image displayed. However, I’m getting a nullpointerexception in ProxyServlet because I’m missing the “url” attribute of the image. Is there a way to display an image from a stringtype?
Example (sitemap):
Text item= Rio_Src_Cover
Image item= Rio_Src_Cover
Example (item):
String Rio_Src_Cover “Cover Art [%s]” { channel=“russound:source:1:coverarturl” }
2016-09-06 10:39:51.513 [WARN ] [e.jetty.servlet.ServletHandler:628 ] - /proxyjava.lang.NullPointerException: null
at java.net.URI$Parser.parse(Unknown Source)
at java.net.URI.(Unknown Source)
at java.net.URI.create(Unknown Source)
at org.eclipse.smarthome.ui.internal.proxy.ProxyServlet.doGet(ProxyServlet.java:162)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
Yes the URL does work in the url attribute. It’s actually a pretty simple change in ProxyServlet to support (psuedo code: if the url is null, get the item and if it’s state is a StringType - put the value into the uriString field). Works for both Image and Video widgets. I have it changed locally (although I’m not sure how to create a jar out of it to test - still getting my head around how all this fits together). If Kai or someone wants me to put in a pull request for it - let me know…
You’d need to modify the source code and recompile OH2 yourself. If your a programmer, simply look for the ProxyServlet in eclipse and make the modification I described above (code is pretty easy to understand). If your not, not sure it would be worth the effort. Since I posted that, I’ve found out (over on the eclipse smart home forum) that there is an UI Image item that can take a raw image data and display the image (unfortunately only supported in the PaperUI for now). That seemed to work great and solve the issue I was having…
